Superman has parts on the way!
Old Nov 23, 2006 | 07:34 PM
  #121
Superman09's Avatar
LS1Tech Sponsor
Bump, would like some more input..... I can do the fuel system now with adding a boost-a-pump, FPR, lines and rails and possibly a meth kit AND valvetrain if its needed or i could hold off..... but is that worth it and will i just want to up it anyway? Any thoughts on the power this set up will make on 5 psi and 8 psi and if it may be too much for the stock motor? Thanks
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Nov 23, 2006 | 09:13 PM
  #122
Murdock's Avatar
What about using 5 psi springs and a boost controller to go higher than 5 if your fuel looks okay?
Old Nov 23, 2006 | 09:16 PM
  #123
02SSLE's Avatar
you need new valve springs for sure.
Old Nov 23, 2006 | 10:18 PM
  #124
Superman09's Avatar
LS1Tech Sponsor
BTW, i plan on keeping shift points in the same spot as stock so i don't think valvesprings SHOULD be a problem but i'll probably pick some up to be safe. Any other input?
__________________
Old Nov 23, 2006 | 10:37 PM
  #125
Ryan K's Avatar
Pathological Modifier
Even stock shift point/rpm, you'll need valve springs.
Old Nov 23, 2006 | 11:23 PM
  #126
Jammer's Avatar
Remember , its not just high rpm you need springs for..sometimes its the spped in which you get to whatever rpm you going too. Add springs in my opinion.
Old Nov 24, 2006 | 07:04 AM
  #127
Superman09's Avatar
LS1Tech Sponsor
Ok, well i'll pick up some springs then. Would some comp 918s be enough or will i need the all out dual golds? As for power levels... what do you guys think i should shoot for, 5 or just skip that and stick with the 8 that are already in my WGs?
__________________
Old Nov 24, 2006 | 09:14 AM
  #128
Superman09's Avatar
LS1Tech Sponsor
Heres what i'm thinking right now, keep the 8# springs, add a MSD BAP to my set up, a snow meth kit, some decent valvesprings, probably add some Comp 918's. From what i'm hearing adding a meth kit will make it much easier on my motor, and it will help out the fuel system so that kind of knocks out my 2 worries. Sound like a good plan?
__________________
Old Nov 25, 2006 | 09:52 PM
  #129
Superman09's Avatar
LS1Tech Sponsor
So what do you guys think? Run the 8 and get a meth injection kit or back down to 5.....
On another note... think the meth kit would help me out tremendously for pump gas, stock motor, street car?
__________________
Old Nov 26, 2006 | 10:48 AM
  #130
SSilverSSurfer's Avatar
so is the BAP an alternative to adding a second pump? can u use the Kenne Belle BAP?
Old Nov 26, 2006 | 11:54 AM
  #131
Superman09's Avatar
LS1Tech Sponsor
Kind of, i'm thinking of picking up the KB BAP to help my fuel system out at the 8# level and when i decide to bump it up from there is when i'll do a second pump...
ANy other thoughts/input?
__________________
Old Nov 26, 2006 | 12:05 PM
  #132
oh i see, i guess i'll do that also until i step it up to larger cubes, i'll be running about 7-8psi, probably with a Racetronix PNP and a KB BAP
Old Nov 26, 2006 | 04:40 PM
  #133
Superman09's Avatar
LS1Tech Sponsor
should be fine, I'm probably going to order a BAP to be extra safe as well.
So what are your guys thoughts on me picking up a SNow Stage 2 meth kit for my set-up.... 8 # twin 60's pump gas street car? Give me your input on it! Thanks!
__________________
Old Nov 26, 2006 | 04:43 PM
  #134
2002/Black/SS's Avatar
at 8 psi u dont have to have meth, but it would help, also meth should never replace ur fuel system
Old Nov 26, 2006 | 04:45 PM
  #135
Superman09's Avatar
LS1Tech Sponsor
It isnt, it will help it i have heard however. I think my racetronix, 65# injectors and a BAP should give me sufficient fuel... just want to know on your guys opinions on whetehr Meth could be quite beneficial or not to my set up? Looking at it as a safety feature basically? Or would it be a waste of cash?
__________________
Old Nov 29, 2006 | 07:51 AM
  #136
solobaric's Avatar
A little off topic, but does the Turbo Zone twin kit route the down pipe under the k-member close to the road, or above the k member tucked up nicely to save it from speed bumps etc...
What are power goals Superman? Are there any dyno charts out there for a TZ kit?
Old Nov 29, 2006 | 11:41 AM
  #137
Superman09's Avatar
LS1Tech Sponsor
their single kit will go above the k-member and my twin will go threw the k-member. I don't think there are any dyno charts out there yet. I think i'm the first twin kit and will/should/hope to have my 8# dyno numbers around Jan-Feb. Power goals are 500 rwhp through the a4 on stock motor.... we'll see
__________________
Old Nov 29, 2006 | 05:12 PM
  #138
Superman09's Avatar
LS1Tech Sponsor
just ordered the rest of my guages and air filters for the turbos..... going to pick up the snow stage 2 meth kit here soon as well!
__________________
  #139
pHEnomIC's Avatar
Ballin'
Old Nov 29, 2006 | 08:06 PM
  #140
solobaric's Avatar
Cool! Keep us posted on the install process and your outcome Superman!!
