PCV Turbo Venting!
Old Feb 5, 2007 | 06:59 PM
Silver02Z28's Avatar
I'm bringing this post back from the dead because I have a question about 2002ws-6's PCV system. I understand how it works and it looks like a good setup.
I have one question about it though. On his first pic I can see where he is drawing in fresh air into the PCV, but on the second pic the check valves look like they close any route to incoming fresh air. It seems like the crank case is being vented, but no fresh air is going back in. Maybe there's enough pressure built from blowby and fresh air does not need to enter while under boost, or maybe I'm not seeing something obvious. Can someone please explain?
I'm just trying to better understand PCVs and FI.
Old Feb 5, 2007 | 08:07 PM
2002ws-6's Avatar
you got it dead on, under boost any crankcase gases built up are what is being vented. No need for fresh air while boosting. It acts just like a car with a couple of breather filters on it.
Old Feb 6, 2007 | 11:55 AM
No Juice's Avatar
Is your pcv set up the same as EGash's first diagram?
If I have a blower would you set it up differently?
Old Feb 6, 2007 | 01:58 PM
Johnv's Avatar
I like the look of this setup (top pic),
does it still use the factory PCV valve as well as the two check valves ?
Was thinking maybe a second unvented catch can in the line to inlet manifold to ruduce any oil vapour entering manifold .
Old Feb 6, 2007 | 03:06 PM
smoke20's Avatar
does anyone have any idea where to purchase the check vavles i have everything else just no check valves.
Old Feb 6, 2007 | 04:16 PM
MIGHTYMOUSE's Avatar
there are 3 parts to my pcv system
line from intake to valve cover(or crankcase) w/ 1 way valve and oil separator
this is a vacuum source to pull air (and a slight vacuum) through the engine when out of boost, and seal when in boost
line from valley cover (or crank case)to in front of turbo/(sc)
this is a vacuum source to pull air through the engine when in boost (low presssure area btwn air filter and turbo/(sc)) and a fresh air source when out of boost (see above)
large home made 1 way valve on valvecover (or crank case)
this allows any positive pressure that may develop to escape quickly and easily
Old Feb 6, 2007 | 04:25 PM
ddnspider's Avatar
will these work for check valves?
http://www.usplastic.com/catalog/pro...uct%5Fid=15641
Old Feb 6, 2007 | 05:03 PM
McMasterCar (McMaster.com) Part number 7775k52
Old Feb 6, 2007 | 05:09 PM
2002ws-6,
I've read on some posts that the vented catch cans are a vacuum leak and you should use a non-vented can. I see a lot of vented catch cans running without any problems though. Have you had any problems?
I see that you are not venting or pulling in any fresh air anywhere else, so I guess you need it.
Old Feb 6, 2007 | 05:13 PM
That's what I plan to run, but with a check valve only (no separator) at intake to PCV valve. No LS6 valley cover, so valve cover to catch can (vented?) then catch can to before turbo. Sound right?
Old Feb 6, 2007 | 11:03 PM
2002ws-6's Avatar
This may make a diff, but my car is runnig an SD 2bar tune. The maf is not providing any numbers for the ECU calc's. I've had no problems at all. The car runs completely normal while not boosting, and it acts like a 1950's car before PCV was even invented while boosting. I can check my old PM's cause I gave the Check Valve part number to somebody. Here is it
Vw/Audi part number 078 905 291 B $18.50 retail
Old Feb 7, 2007 | 02:14 PM
  #32
ddnspider's Avatar
can someone tell me if this will work?i like $1 a piece vs $16 a piece
http://www.usplastic.com/catalog/pr...duct%5Fid=15641
Old Feb 10, 2007 | 08:39 PM
  #33
WicketMike's Avatar
why not just block off the line from the intake and the throttlebody and just run a catch can from the lines from the valve covers without any check valves ?
Old Feb 10, 2007 | 10:05 PM
  #34
BigJls1's Avatar
guys looking for check valves
I fabed a custom gas tank once and needed a check valve
like a one way vented gas cap any way
heres what to do :
get the summit or jegs fuel tank rollover check valve
take the an6 or an8 piece off the will be a steele in there.
go to ace hardware get a spring (pusher style) maybe get a couple on strenghs , based on boost levels, reassemble with spring pushing the ball agianst the seat inside you have a check valve
Old Feb 10, 2007 | 10:08 PM
  #35
BigJls1's Avatar
[IMG]C:\Documents and Settings\Owner\My Documents\My Pictures\full force pics\dads gas tank\P9220023.JPG[/IMG]
Im tryiing to post a pic for the first time of the check valve
let see if this works
Old Feb 10, 2007 | 10:09 PM
  #36
BigJls1's Avatar
didnt work hmmmmmmm any help out there
Old Feb 11, 2007 | 08:45 AM
  #37
you need to put the photo on the internet, your link is where it is located on your computer
Old Feb 11, 2007 | 04:33 PM
  #38
stevieturbo's Avatar
because that would be far too easy
Old Feb 11, 2007 | 06:13 PM
  #39
Eatinstang4life's Avatar
I also want to know if these would work??
Old Feb 11, 2007 | 11:20 PM
  #40
WicketMike's Avatar
thats what i ended up doing about a month ago, seemed alot easier and less to deal with
