bout to start a turbo project
FI needs fueling and lots of it. Dual intank pumps isnt worth the headaches. Dont forget at least 83lb injectors.
Ill be running 96's but even those wont be enough for high boost.
*Edit*
JP, there are things in this forum that you will read and people will suggest....The concept ive built my setups around in the past has been "Keep it Simple Stupid" It goes a long way in these builds too. Start getting and fabbing up trick stuff, (dual Intanks for example) sure it may work, but its not something id suggest to run...One big external is safer, and easier to work on if issues arise.
for the injectors to work with the stock PCM. Then kick the bad boy into SD 3 bar and go to town tuning!http://psj.ls1tech.com/gallery/main....d=10&g2_page=5
My take... If you only want like ~700rwhp, I'd look into a PT88 with the T4 flange since it will be easier to package. If you really think that you will want to run mid to low 8's someday, go with a bigger T6 flanged turbo. I'm at the very beginning stages of racing my car, but I did have it set up so that I or anyone who ownes the car could upsize to a GT55-91 turbo.
I'd say if I was doing it all over again, I'd run a 370ci motor with the same turbo I have. I'd probably run ~8.5:1.
BS3 is an option since the guy that inventeded is a relative of another friend of mine. We thought about going in to buy 4-5 setups for all of our cars that are coming out in the next few months but I havent heard much talk about that lately. Everyone is tight on funds around the holidays.
More then RPM, LG, Dallas Mustang, and others that have complaint lists and bad talk all over.
As far as pot and kettle. Anyone that posts props to a shop is automatically a nutswinger?? Naaaah. Billy's prices and level of service is great... so is SQR's........ meanwhile others are in Lewisville payin 600+ for a freakin cam install......
Nate...... you should know this! I also was just givin ya a hard time.
Back on topic. Sorry JP!
*Edit*
I agree with you on the fuel pump, one is also easier install but two would work too. And I would go gen 7 but I'm broke this year. maybe next winter I'll swap. For now it's an injector driver with like 2 bar. no three bar for 98's. sucks but oh well it'll be only a year. and I'm gonna run some 96's also. go with the biggest turbo you can afford.
