high hp turbo timing/fueling help
is there a rule of thumb or any real world experience on how much timing you need to add when switching from pump gas to race gas just to make up for the slower burn rate of the race gas?
i was told minimum timing should be at peek tq. is this true?
i was also told to keep prety decent timing in it while spooling and that would help it to spool faster. is this true?
i was also told to keep it lean(not super rich anyways) while it is spooling up and it will spool quicker. is this true?
i was told more timing in the upper rpms will help with the power up there? is the true? if so how much more timing? lets say i am at 15deg at 5000rpm and thats my peek tq how much timing should i be looking at around 6500, my peek rpm?
i was told when playing on the dyno to add 2 deg at a time and i should see significan't power each time. once i dont see a nice gain like 35hp then go back to my previous timing numbers and call it good. this seems reasonable. anyone disagree? if i keep gaining power as the timing goes up is there a max timing number i should just stop at?
i am sure i will have more questions. right now i am running the same turbos as many supra guys. they have 3.0L and one turbo and i have 6.7L and 2 turbos. i am told they see 30psi by ~4000rpm. i see 23psi by 4700rpm. with the extra cubes i would think i should be spooled sooner than them. is it tuning or maybe the turbo kit design(log headers). the local dyno is very reasonable so i will have some time to try diferent things. i just want to have a good idea of what i want to try.
TIA
1. More timing makes my combo spool quicker...I actually dropped timing down low to keep from blowing the tires off.
2. More timing up top does help my combo hold hp up top.
3. My min timing is at max torque.
4. My timing curve is U shaped.....starts at 17 drops to 14 at peak torque slowly ramps up to 18 at 6000rpm......I drop the start of the U down 2 degrees if the track is sorry.
Good luck!
i posted up my timing chart a while back.. here found it..
i'd like to see the same screen from Mike Brown.
I have very little difference between peak torque/hp in my timing maps on a 402ci engine. Generally picking common points I have 19 degrees at 5500 at 22 psi, then it tapers to 21 degrees at 8500 still at 22 psi. It will depend some on the cylinder head, generally better heads will use less timing at a given boost number.
With the intake you are using I generally remove fuel from the corner cylinders. In the Nova I have correction at -6 on cylinder 7 and 8 and -3 on 1 and 2. This engine has the throttlebody on the rear (pointing towards back of car). I do this with the chassis roll, I just clean cut the engine at the end of a run, then line all the plugs up. Adjust fueltrim for a uniform color.
Spool timing. I have timing at 4500 (this is two step set point) 33@2psi-32@4psi-31@7psi-24@11psi (it normally leaves here) 21@15psi. The high early timing helps to "bring it up". You may want to alter injector timing on buildup to help it spool.
Kurt
13:1 A/F and 28* of timing helps to get mine spooling. I bring in more fuel and start dropping timing as the boost rises. Auto cars= more timing/less fuel. Manual cars= less timing/more fuel.
Kurt
up top i picked up 43hp at almost 2psi less boost. this is at 21deg peek timing and 19.5deg at peek tq. the run from before was 16deg all the way across. it also picked up some nice power in the lower rpms even though it was spooling slower. i need to work on my valve train so i can carry this power into the higher rpms.
here is a link the a more detailed post >> https://ls1tech.com/forums/forced-induction/592346-back-dyno-again-1055rwhp.html
