View Poll Results: Pick one
Manley 2618 with 22 cc dish. 8.9:1 C/R
9
4.29%
New Mahle Boost pistons with 26cc dish. 8.7:1 C/R
44
20.95%
Wiesco Turbo pistons with 32cc dish. 8.4:1 C/R
59
28.10%
Dimond pistons wiith 20cc dish. 9.0:1 C/R
98
46.67%
Voters: 210. You may not vote on this poll
Which piston? Pick one
Old Oct 14, 2006 | 09:23 PM
mahhddgtp's Avatar
Originally Posted by 427
We have seen them start to lose performance as the ring grooves wear. This seems to start about 5-7000 miles in. It would be interesting to put them in a engine and inspect every 2500 miles to see how long they last.
It would be nearly impossible to limit by rwhp because drivetrain changes the output at the wheels. If you have a reasonable tune in the car, I would not be scared at 1000hp flywheel with boost on 4032. If you have high nitrous loads then 2618 would be for you.
Kurt
Okay then. Now I can sleep a little better at night
Old Oct 14, 2006 | 10:40 PM
427's Avatar
427
When you saw the 4032 piston that failed, what was wrong with it. Did it have cracks or melting damage?
Kurt
Originally Posted by LSs1Power
650rwhp is over the limit of the 4032 based on what i saw. I think W2W has pushed the 4032 over that, but i didn't find anyone else doing the same. I can see using the 4032 on a maxed out maggie or P-1SC with 346-364 engine setup, but thats about it. I say magnacharger and P-1SC because they tend to max out under 600rwhp no matter what u do with them. I know some P-1SC made slightly over 600rwhp, but that isnt the norm.
Old Oct 14, 2006 | 10:42 PM
LSs1Power's Avatar
Kurt
Cracks which leads me to believe its a strength issue more than tuning gone bad. I will have to search for it again on Google, but it wasn't on a LSx based engine. It was on an EVO engine.
Old Oct 14, 2006 | 11:43 PM
MiaSSmaro98's Avatar
guys how come it takes a 20+ -cc to have a compression lower then 9.0?a sponsor told me that with a dish piston with -9cc will give the compression in my sig with 71 cc heads
Old Oct 14, 2006 | 11:46 PM
LSs1Power's Avatar
It depends on the displacment. The larger the displacment the larger the dish cc size to maintain the same compression. For example on a 370 shortblock a 15 cc dish with 72 cc heads will put u around 9.0:1 while it takes 20cc to do the same on a 402 shortblock.
Old Oct 15, 2006 | 01:04 AM
BIG BAD BLACKSS's Avatar
370 with -14.9 pistons and 72 cc head will put you at 9.2
Old Oct 15, 2006 | 04:10 AM
LSs1Power's Avatar
I said around 9.0 because there are other small factors such as gasket thickness and deck volume which could change the compression ratio slightly.
Old Oct 15, 2006 | 05:42 AM
well i will be biulding a stock 346 displacement motor so it will be true wat it states in my sig with a -9cc?
Old Oct 15, 2006 | 09:35 AM
cablebandit's Avatar
yes, i had that combo...diamond -8.6cc pistons..72 cc heads for 8.79:1
Old Oct 15, 2006 | 03:54 PM
LSs1Power's Avatar
Yup it will put u around that compresison.
Old Oct 15, 2006 | 09:31 PM
awesome thanks guys
Old Oct 19, 2006 | 01:23 PM
  #32
JTSLP559's Avatar
mahle boost pistons are what i had..never had a problem with em
Old Oct 19, 2006 | 01:40 PM
  #33
SS00Blue's Avatar
While I concede to Kurt's eminent expertise, piston scuffing is easily controlled by proper piston-to-cylinder clearance. The down-side is a little extra noise on cold start. Coatings help! If your build is designed for maximum strength, there is no choice: Weisco or Diamond, both of which I have run boosted (25PSI), sprayed (250 shot) and N/A (10.30 @131 in the early 90's).
If you're looking for a medium performance build, Mahle makes a good alternative, though they are only advertised as a "Sportsman" piston. JE is a great BBC piston, but the rest of the blanks are machined, not cast, as a Brand F and C piston.
Diamonds are what I have found live. I've reused them in very high HP apps.
My respects to Kurt... Birdie says "HI"...
SC-
Old Nov 26, 2006 | 04:30 PM
  #34
I'm looking to run about 15PSI on my 370 with up to a 100 shot on top of it. I got diamonds.
Old Nov 28, 2006 | 04:53 PM
  #35
Smearin's Avatar
Im kind of curious as to how many of you guys drive your cars with the forged setup on the street...
How many miles you guys have accumulated on your setup??
Old Nov 29, 2006 | 09:41 AM
  #36
briannutter's Avatar
Default see for yourself!
Hey there, I thought I'd throw this out.... if someone wants a Wiseco in 4032...that's not a problem...just do it as a custom. NOT a big deal. The added expense is nominal especially when you consider the bore, height, and Compression ratio is exactly what YOU want. Zylan skirt coatings, heat barriers, different ring packs, and Tool Steel pins are all options.
Simply put, Wiseco prefers 2618 for our stocking parts because they don't break as easily. I think the other U.S. piston companies would agree...One post of an exploded/cracked/shrapneled (insert brand here) piston on LS1 tech means your name is dirt. 2618 lessens that possibility. If customs are done, the engine builder takes the responsibility for alloy choice.
As for 2618 pistons needing to be replaced all the time, I have yet to get a call from a LS1 customer that needed replacement pistons because they simply "wear out". They'll last longer than the bore and many people have re-used Wiseco pistons in multiple blocks. The pics I'm posting are of an ANCIENT set of our k061a3 strutted pistons from Finish Line racing school. We got them back a month ago and I got the whole set. We've updated the forging since then, but judging by the fact the inside of the forging isn't etched and the skirts aren't even diamond turned, they are from the early 90's. They've been through 5 blocks and have 130K laps on them...no exaggeration. If you figure students run 5 laps at a time on a 1/2 mile track, that's 26,000 times that someone has gotten in and out of the racecar. I don't know what that relates to in start ups, but these had 65k RACE miles on them. The school's owner COULD and WOULD have reused the pistons again, but he sent them to us as a present because he's so happy with them.
As you can see, the skirts look nice and the pin bores are beautiful. The strutted 2618 k061's are designed to be run at .0055" clearance. These skirts now measure 4.024 which means they wore .001". Our LS1 pistons at .004" with a more forgiving forging design, so they don't take the same beating at start up as the k061's do. This is not an anomaly either, Petty Driving school reports 45K miles on the sets we've done for them before they're retired.
When we offset the wristpins, the pistons are quiet. When we dial the cam and taper of the skirt in properly, the contact pattern is widened and the unit loading of the skirt is lessened and they last a long time. When we use a dedicated forging, the weight is low and more than offsets the 3% weight difference of our competitions 4032 forgings..Our 4.125 bore size BIG -32cc dish 427 piston weighs in at 430g...That's light considering the regularity of 800-1000whp engines these days that these pistons operate in. For comparison (on a 1.115 compression height piston), our standard ring lands are .260" top, .170" 2nd, and .080" third. Lands can be made thicker as customs if a different ring pack is used.
Hope this helps your decision making.
-Brian Nutter-Wiseco Piston
Attached Thumbnails Which piston? Pick one-finishlinek0612.jpg   Which piston? Pick one-finishlinek061-btm3.jpg
Old Nov 29, 2006 | 10:05 AM
  #37
eb02z06's Avatar
Wiseco's are what's going in my LS2-I still cannot believe this thread has been going this long trying to dsecide between a 4032 or a 2618 forging-I don't understand Mahles logic-maybe factory repalcement or equivalant is a better choice of words.
Old Nov 29, 2006 | 10:11 AM
  #38
427's Avatar
427
53,000 on my boosted 6.0 with Mahle 4032 pistons. Still leaks down perfect.
Kurt
Old Nov 29, 2006 | 07:23 PM
  #39
Smearin's Avatar
Awesome responses...
I guess its just a matter or preference for which alloy..2618 just being stronger of the 2
Old Nov 30, 2006 | 12:17 PM
  #40
427's Avatar
427
2618 is much better suited to taking a beating, it is not stronger. The ring lands in a performance engine will last longer with the 4032 material in our testing. The 2618 material is our choice for high hp builds (over 1000hp we will not give you a choice). The 4032 is our choice for high durability medium hp builds as it will hold "new" power/ring seal longer. You can run a 2618 for long periods of time if power loss is ok.
Kurt
