what Rad. are you guys using?
And an LT1 rad is bigger than the LS1 - it's the same as the SLP perf LS1 rad.
I just got off the phone with Spal and they said they don't make a Single 16inch Fan straight blade that flow 2800 CFM but they make one that flows 2360 CFM, and for like $16.00 they sell a kit for you to bolt it up to a radiator (seemed simple enough) They sell the fan for $157.00 and they told me it would be cheaper through a Dealer.
Kyle I would still like to hear from you about the part number you used, and how difficult it was to attach the Fan to the radiator. Thanks man.
Your single seems to be working Fine.
that might be it... ill look...
do you think you would have room to have pusher fans in front of the radtiator? id like to keep them up there to give me plenty of room in the engine bay for the d1sc and mabey a f1c/r later on down the road...
Thanks,
Tyler
http://store.summitracing.com/partde...5&autoview=sku
whats the difference between the two.. all i see is it says tube size 1" vs 1.25"
are these the tubes the coolant runs through, the overall dimensions are exactly the same
$70 difference
