New Project 408 and GT 42 76 Turbo Rear Mount
Old 10-19-2006, 09:54 AM
  #41
RealQuick's Avatar
Originally Posted by smokinHawk
did you guys ever measure the back pressure with that yet?
how high are you reving it?
also what were they highest dyno numbers on his set up, i think i missed it.
820rwhp @ 14psi I believe on 93 octane... that car is a monster.
Old 10-19-2006, 10:05 AM
  #42
FastCashDave's Avatar
When we first put my setup together we had some big back pressure issue's.
We were only running one 46mm wastegate
So we added another 46mm wastegate and It fixed it.
So we are putting 2 36mm wastegate's on this setup, and we are hoping that will take care of this issue
Old 10-19-2006, 10:09 AM
  #43
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,141 Likes on 741 Posts
Changed your name. Keep us posted. How come folks are saying rear mounted turbos will have less backpressure given the same turbo? I would also then say that the rear mount will make less power.
Old 10-19-2006, 10:12 AM
  #44
John
Thank you so much for the username change, you the man
As far as the turbo we are going to go ahead and try it because we already have it.
However I should go ahead and order the T88 and have it here for standby
I get all the names and numbers mixed, up so Dave you have a T6 flanged 76mm turbo there? Based on what I've read, it's too small for your engine, but if you already own the turbo put it on and max it out. Maxing it out means you will only make a certain amount of boost, and beyond that it will just make the same power and more heat.
Old 10-19-2006, 10:17 AM
  #45
Zombie's Avatar
I'd say they have more backpressure from what i've seen so far, but the hotter you can keep the exhaust the lower the back pressure will be. I also believe that the overall HP will be a little less, mainly due to the back pressure since it creates pumping losses, along with longer pipes and more pressure drop in the charge pipes, probably only about a 1 psi difference though.
Even if it only works 90% as good as a front mount, thats still a butt load of power. I know my car has no spool issues and is lots of fun to drive.
P.S. I also say put the gt42-76 on it and max it. It's going to be very responsive and a lot of fun to drive.
Old 10-19-2006, 10:19 AM
  #46
John
What kind of power is your 98 Formula: 348ci | GT 47-88 Making ?
Old 10-19-2006, 10:22 AM
  #47
LS1Tech Co-Founder
800rwhp, 26psi
I used to make 680rwhp, went 9.4@143.
So I think that I have to get full good runs at the track to see if I have a decent torque converter in my car.
Old 10-19-2006, 10:38 AM
  #48
LS1TECH Sponsor
DrTurbo's Avatar
Is that a typo?? 26psi and 800rwhp?? I figured maybe 16psi and 800rwhp would be about right.
Old 10-19-2006, 11:58 AM
  #49
RealQuick's Avatar
Seems like alot of boost for a big turbo...
You figure if he had a manual tranny he would have been around 875-900rwhp... but thats at 26psi... still a ton of psi.
Old 10-19-2006, 12:41 PM
  #50
LS1Tech Co-Founder
You guys generalize too much about dyno numbers, thats' why I posted 680 vs 800rwhp numbers.
Old 10-19-2006, 12:54 PM
  #51
Fireball's Avatar
well you were having valvetrain issues at the track right...whats to say it wasn't doing it on the dyno? 26 lbs should push you ALOT higher than 800
Old 10-19-2006, 12:55 PM
  #52
RealQuick's Avatar
Dont take offense, nobody said your car is gonna be slow. The amount of cfm that big turbo is pushing... you would think it would make more power @ 26psig... thats all.
Old 10-19-2006, 01:01 PM
  #53
Zombie's Avatar
I'm with you, too much emphasis on dyno numbers. My car makes 470 the wheels @ 15psi according to the dyno. That same 470 also takes my heavy car to 129mph traps.
People need to start taking type transmissions into account when looking at numbers. With a non-lockup converter you don't get accurate numbers. Dyno's are only supposed to be used for tuning.
Old 10-19-2006, 01:09 PM
  #54
JTSLP559's Avatar
wow.. your setup is bitchin, i cant wait to see some numbers!
Old 10-19-2006, 01:18 PM
  #55
LS1Tech Co-Founder
For now I just go off of facts, I went 9.4@143mph at the same raceweight and with the same converter and everything in my car.. at 680rwhp. So I like to think that I will go 10mph faster with the turbo setup. I have some valvetrain problems but we'll see if that makes a difference in anything. After reading around, I basically found that most A2/A3 dyno numbers are all over the place.
Old 10-19-2006, 04:14 PM
  #56
NA$TY-TA's Avatar
Originally Posted by FastCashDave
The physical size of this thing is larger that my T88.
This thing is a monster.
But not bigger then an S88
Like realquick said... you can always swap it out for the S series turbo's from Jose... if ya go with a Reg 88mm turbo with a T4 flange you would have to change piping and other things..... ALL of the S series Turbo's swap out and bolt in exactly the same as the GT42-76 with a T6 flange... i know... thats what we did with mine....
PSJ,
Dont worry buddy... Dyno #'s dont mean crap.. track #'s is where its at.....
Kyle
Old 10-19-2006, 06:42 PM
  #57
2000 Tran Zam's Avatar
PSJ,
Kyle
Says the guy with 850+rwhp through a A2
Old 10-20-2006, 09:12 AM
  #58
NA$TY-TA's Avatar
ha ha ha ha LOL
The wastegate im using is a 48mm Turbosmart unit and i have no probel even when trying to run 8psi....
Kyle
Quick Reply: New Project 408 and GT 42 76 Turbo Rear Mount
