question about boost?
Old Oct 18, 2006 | 08:46 PM
camaroperson69's Avatar
Default question about boost?
hey guys, i have a 2002 camaro SS and it is all stock.i wanted to know if i can put a procharger kit on it. i dont want to do anything to the drivetrain.it will be running 8 lbs of boost.is their anything that i will need to do this?wen it is done it should have around 500 hp.so i just want to know if i need anything else
Old Oct 18, 2006 | 09:02 PM
Jake@EPP's Avatar
The stock clutch will need to be upgraded. Also, you can get by for a while on the stock rear end, i know you dont want to upgrade it but its going to be one of the weakest links in the system now.
Any other questions, just ask!
-Jake
Old Oct 18, 2006 | 09:43 PM
pwrtrip75's Avatar
On street tires your stock rear might be ok for awhile....but 500hp on street tires is kinda worthless unless your doing over 50mph.
Old Oct 18, 2006 | 10:14 PM
thanks guys
Old Oct 18, 2006 | 11:23 PM
Bird-Of-Prey's Avatar
You say you don't want to do anything to the drivetrain but hopefully you have taken into account to at least upgrade the fuel system. This is a must with FI. Another must is a good tune with a wideband. NGK TR-6 plugs are recommended. If you decide not to do these upgrades and take your chances, I wish you luck because your new found power will be very shortlived.
Old Oct 19, 2006 | 04:58 AM
EPP's Avatar
EPP
Here is our installed ATI ProCharger D-1SC price.
http://www.exoticperformanceplus.com....php?service=5
Here is a list of items I recommend.
http://www.exoticperformanceplus.com...php?service=66
The ATI ProCharger P-1SC complete kit will supply you with the ProCharger kit, plus the injectors, fuel pump and a tune. On top of this I would add subframe connectors. Give me a call for a great price on the ATI ProCharger kit at 260 244-4808. Bob
Old Oct 19, 2006 | 03:19 PM
yea but too bad i live in new jersey..so i wont be able to have it done their
Old Oct 19, 2006 | 03:21 PM
what is a good tune with a wideband?
Old Oct 20, 2006 | 05:07 AM
EPP's Avatar
EPP
Thumbs up
Not a problem, give me a call for a great price on the ATI ProCharger kit at 260 244-4808. Bob
