what converter for turbo setup?
Old Oct 25, 2006 | 07:48 PM
nick97ta's Avatar
Default what converter for turbo setup?
looking to get a converter to best work with my setup, best for the track not street.
the car is a 97 TransAm with-
383ci
76mm turbo
9" rear with 4.10 but my switch to 3.73
th400 trans. brake
car is 3500lbs
28-10.5 et drag
the trans. needs to come out anyway for a bad leak. I have a 3800 ptc and get 4600rpm on the brake, on the street it goes through the gears very fast and I dont think it would get to the 1000ft mark with any rpm left...
Old Oct 25, 2006 | 08:22 PM
Spdmini's Avatar
switch to 3.73s while you have the trans out.. Im gonna have a 3600 in my car w/ 3.42s
Old Oct 25, 2006 | 08:45 PM
nick97ta's Avatar
just to let everyone know we only have 1000ft track here in arkansas....
Old Oct 25, 2006 | 08:54 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I still don't know if my TCT 'blower' converter is going to work with my new turbo setup... too early to tell.
I'd go less gear 3.73, I'm running a 3.50 in my 9".
Old Oct 25, 2006 | 10:30 PM
Zombie's Avatar
I'm running a Vigilante converter, very tight on the street, can cruise below 2000 rpms in 3rd.
I'd also go lower than you 3.73 gear if you plan on driving on the street. I swapped from 3.50's to 2.75's and my sixty foots actually improved. I was unable to hook on 3.50s
Old Oct 25, 2006 | 10:50 PM
RealQuick's Avatar
Nick, you ever get your setup dyno'd?
I agree on going lower with the gears too... more load = faster spool
Old Oct 25, 2006 | 11:02 PM
nick97ta's Avatar
no I have not dyno'd it, still have alot of thing to work out before that point, like pulling the trans. and getting my leak fixed, it is very bad!!!!
the car is more of a track car now but I do still have a/c and full interior, thats y this thing is 3500lbs.
In time I will build another long block and step up on the boost(only 10psi now), I'm looking for the 1000hp mark at the flywheel and would like the converter for that engine not the low hp. slug I have now...
on the spool part I go to 1/2 throttle and about 3500rpm and the w/g open, then on thr t-brake it gets full boost very quick.
Old Oct 26, 2006 | 11:36 AM
Yank's Avatar
Give me a call at 775 826 9955 so we can help you decide
Dave
Old Oct 26, 2006 | 11:43 AM
JMBLOWNWS6's Avatar
Dave
Dave the converter feels awesome. Check out this post https://ls1tech.com/forums/showthrea...3&page=2&pp=20
Scroll down a litte
Old Oct 26, 2006 | 11:44 AM
HAMRHEAD's Avatar
I use a Neal Chance 3800 and 3.25's in the 9" 3.73's won't load up the turbo as well. It would hurt your times.
Old Oct 26, 2006 | 11:51 AM
G5TA's Avatar
Where in Arkansas are you from i just moved to Monroe LA. I work about 30 south of El Doradlo
Old Oct 26, 2006 | 12:05 PM
DrTurbo's Avatar
LS1TECH Sponsor
Which 76mm unit and what A/R?? That makes quite a bit of difference.
Old Oct 26, 2006 | 12:17 PM
engineermike's Avatar
4600 rpm on the transbrake is pretty good, actually. My last converter was flashing to 5400 and it still ran good numbers. I think your gear ratio is the problem, not the converter. Like others have said, the 3.73 will still be too much. I just switched from 2.73 to 3.00.
Old Oct 26, 2006 | 12:46 PM
Zombie's Avatar
What do you think of the gearing change? Better, worse no difference.
Old Oct 26, 2006 | 01:23 PM
WAHUSKER's Avatar
A couple of us out here run the ProYankExtreme 3400 & love it. (the other car has a 370 with a t-76 turbo) Very tight, runs cool, nice street manners, and yet flashes high & makes good power for the dyno / track.
Old Oct 26, 2006 | 03:33 PM
TrakDay's Avatar
Yeah... I have a blower converter in my th400 also and am hoping it will be up to the task with the twins. I don't want to have to go and redo it again...
3.5 gears in my 9" also and intend to run 28" tires!
Old Oct 26, 2006 | 03:46 PM
SlpLS1's Avatar
id switch it to a smaller gear
Old Oct 26, 2006 | 06:49 PM
nick97ta's Avatar
do turbo car's run that much more power and tq. that thay can run that high of a gear on a 90%track 10%street car?
Central Arkansas about 20mi north of North Little Rock.
gerret gt42 76mm I forget the A/R. it is the T4 flange one.
Old Oct 26, 2006 | 07:16 PM
I'll let you know after I go to the track. I had run 10.40 at 143 mph. I increased the cid, advanced the cam, changed the converter, and added gear and we'll see what happens.
Old Oct 26, 2006 | 07:20 PM
Yes. Do the math yourself if you want. Figure 140 - 150 mph in the quarter, 10% converter slip, a 26 or 28" tall tire, and a power peak at 5600 rpm and you'll be surprised how tall the gear needs to be.
145 mph, 26" tire, 10% slip, 6100 rpm: 2.82/1 rear gear
