Cooling Fan Relocation Questions
Old Oct 27, 2006 | 08:31 PM
BadgeZ28's Avatar
Default Cooling Fan Relocation Questions
I am moving fans to pusher position but already I am seeing higher temps. I think the AC cooler is just to compressed to allow much air through to the radiator. I would like to keep the AC. Is there enough room to separate the AC cooler from the radiator to allow room for a four inch deep electric fan? Car is a 01 Z28. Thanks.
Old Oct 27, 2006 | 08:37 PM
BigBenz's Avatar
How are you relocating it? I would like to see some pics of what you done.
just lose the AC im going to.
Old Oct 28, 2006 | 09:11 AM
Country Boy's Avatar
Senior Member
I have a/c. I used two thin pushers and I just added a 12" puller on a switch so I only use it when I need it.. No more problems.
Old Oct 28, 2006 | 10:46 AM
BadgeZ28's Avatar
Country Boy, are you pushing through the AC condenser? What size are your pusher fans? Thanks.
Old Oct 28, 2006 | 10:50 AM
Senior Member
yep. Theyre the FAL 240s http://www.jegs.com/webapp/wcs/store...tegoryId=10117
Old Oct 28, 2006 | 04:51 PM
MiaSSmaro98's Avatar
country did they fit perfect?any pics
Old Oct 28, 2006 | 05:53 PM
Senior Member
slid in right infront of the condensor. Ill get a few tomorrow.
Old Oct 28, 2006 | 09:31 PM
awesome would really wanna see pics.at what temps did the car run with only the duals upfront?before adding ur additional fan
Old Oct 29, 2006 | 01:41 AM
Senior Member
I needed the 3rd fan, but itsl all abut climsate (im drunzk!)
