Let's talk about PSI and how cams affect it...
With the smaller cam the air charge will not make it to the chamber, which results in higher manifold pressure, while the larger cam will allow that same charge to make it into the combustion chamber due to holding the valves open longer, which results in lower manifold pressure but yields more power.
Thye general idea people have is that a bigger cam will always have a lot of overlap, which in general is not wanted in FI applications. This really isnt true. You can have a large cam ground that does not have much overlap, you just have to understand cam design a bit.
Too many people are always concerned about boost numbers, like thats what makes power. Its all about getting as much air into the combustion chamber as possible, not making boost.
"my explanations seem on point" well, im no expert so i dont think im quite there yet... but thanks!! LOL
I'd gladly lend my car to a shop to have the testing done. (and i get to keep the cam that works the best
) NA cars run big heads & cams & spin high to make power....and they do this by moving more air. A boosted car doesn't "need" that much cam because we are forcing air in. That said more cam can make more power IF you spin it high enough. But it's all about matching the cam to your setup. Too big is as bad as too small.
my car has a big cam to shift my powerband up to match the higher boost threshold of my big turbos. it doesn't make sense to cam the car for low end when I don't see boost untill 3500. that would be a horrible mismatch. let's all remember that the entire combo is what counts...not just the cam.
I think you should cam the engine for the rpm range that you intend to use, THEN add fi. the only concession for fi that I would make is a wide lobe seperation.
and Vince, Phil has a larger cam for higher rpms and/or larger engines.
what do you mean when you say BIG cam?
some of the gn guys run 110 lsa's on their turbo engines so I dont necessarily buy the higher the lsa the better.
i think its all in where you want your the meat of your powerband to be, where you want your peak numbers to be, and maximizing the efficiency of your particular setup.
I definitely feel that you can't generalize and say to use brand x cam for turbo and brand y for superchargers. It has to be matched, to rear gear, torque converter, what heads your using, what your goal is with the car be it a street car or all out race car, etc etc. (I wonder if Comp Cams is a member of this site and can shed any info)
this is a good discussion, the only way to know for sure is to have two ls1 mules, one turbo and the other supercharged and try out and see which cams really work.
Also when you run major power and big blowers/turbos you can afford to bleed off a little boost if it will help you in another area.
Read over the threads about cams that Patrick G starts, he is like the cam guru around here. he has a lot of great info on cams such as overlap, duration, and LSA.
its confusing but makes sense. it would be cool to see some real testing though to prove the theories.
I spec'd my cam for my car 224/230 on a 115, at the time I thought I picked it right but now I'm not so sure.
Take a fan(blower) and connect it to a piece of pipe and put a cap(valve) at the end of the pipe to seal it. Now turn on the fan and cap the pipe closed for 1 second and you will have a slight amount of PSI built up in the pipe. Now turn the fan on and cap the pipe again and leave it capped for 1 minute and then turn the fan off. Now you will have a lot more pressure built up inside the pipe compared to when you left it capped for only 1 second. The amount of time that you left the pipe capped is the equivilent of a cams duartion. More duration = less boost which will yield more air in the combustion chamber to be burned.
Thats is the basics of valve events on boost.
I had an interesting conversation with a local turbo guru tonight. He races a car that runs in the 8's with twin turbo's and a blow-through carb. At one point, he swapped from a 242/242-114 cam up to a 259/259-114 and, lo and behold, the car ran faster with the bigger cam at the same boost level.
Mike
Mike
and this particular discussion is not sticky worthy....least not yet.
Mike
Most of what I stated already was based on a supercharger since there are a lot of different variables that affect turbos such as exhaust velocity, which a cam can have affect on.
Mike
lets clear up the mystery.
