Which Bypass Valve (Vortech)
Originally Posted by frcefed98
Would you run a BOV on a supercharged app? You could but it would drive you insane in about 2 days.
I would class my Greddy's as BOV's ( indeed I would class a Mondo the same way )
I had actually expected them to annoy me, but they really arent that bad.
I have one mounted before, and one after the intercooler.
Bypass, bypasses the air out the valve before the boost ever builds(idle and cruise conditions), it slams shut when getting into boost, positive manifold pressure and releases the charge when the throttle is closed. *I've read* if not recirc'ed, and vented to atmosphere the IAT's and IC temps should be a tad lower since your aren't pushing a substantial amount of air through the IC. With the mondo on my D1-SC it definately pushed A LOT of air out the valve at idle and a whole lot more at cruise, so I can see the cooler IAT arguement being somewhat right. Anyone who runs a Mondo bypass or ATI race ready bypass will tell you these things move a lot of air at idle and cruise as well.
BOV's only "blow off" after the throttle is closed after boosting. Most are closed at idle and cruise.
But you should size either to your set ups boost levels to save wear and tear on the headunit(turbo or s/c) my understanding of it
![Thinker](https://ls1tech.com/forums/images/smilies2/thinker.gif)
Mike
Yeah I had one of those crappy turboxs BOV's too
j/k...but i really had one.
I was also going to add that in about the spring and or washers to keep it closed at idle, but figured most people know that already.
tis why I posted most...some people like to run their BOV's with them "cracked" open at idle.
The bypass from ATI or Vortech is designed to be open at idle and cruise.
![1poke](https://ls1tech.com/forums/images/smilies2/1poke.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
TECH Cry Baby
BOSS APPROVED!
![](http://www.freeimagehosting.net/newuploads/ad8zd.gif)
Anyone who runs a Mondo bypass will tell you these things move a lot of air at idle and cruise as well.
The thing is louder than the Procharger. In addition I have had some dumbasses tell me I have a severe vacuum leak (Mondo at idle)
![Rolleyes](https://ls1tech.com/forums/images/smilies/LS1Tech/rolleyes.gif)
took my car for a spin last night, to "test" it out
don't think I have any problems with what I have but it still would be cool to have the mondo bypass valve. I wonder though if i'm at the limit of what I have though. I'd like to throw the mondo on there and see if I pick up any boost.
If the mondo's that loud and annoying sounding i might have to pass up on it though. is there a quieter one available?
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
