OFI F-body Hot Parts coated on engine
Originally Posted by sb427f-car
Ahhhh...I gotta go change ma pants...
j/p...that's purdy.
What needs to be removed/relocated to run that?
j/p...that's purdy.
SSU'S Vice Mod
Originally Posted by tt427ls1
Nothing if your going with a air to air setup. If your going air to water you will have to move the battery to the back.
Just curious, what happens to the ABS pump/module asm? Looks like the driver's v-band joint is right where the abs pump is. Kinda hard to tell with it mounted on the bare long block...
#32
The 4" is going to be tricky. I have a idea in my head and its working as we speak. Just need to tweak it some. Lets just say that it is a $ downpipe.
I've got faith you can snake that 4" pipe thru there.
Brian A.
#38
whats up joel. you still taking orders or are holding off? Also, you think you can work any other colors that will hold the temps? Im thinking maybe a glossy black if possible....
#39
Originally Posted by 2002 Trans Am
Damn that looks really good. Can't wait to hear peoples report on the streetability/effectiveness of the A2W setup for daily driving
#40
Originally Posted by LS2Camaro
Radiator in Stock position, but radiator comes with kit. custom built to fit with kit.
