Max boost?
Old Nov 4, 2006 | 01:56 AM
trey04gto's Avatar
Default Max boost?
Just want a little input...What is the max boost you guys would run on a 9.9CR with a forged bottom end?
Old Nov 4, 2006 | 01:59 AM
Got Me SOM's Avatar
depends on your tune and fuel system, but usually around 12-14 lbs depending if its supercharger or turbo.
Old Nov 4, 2006 | 05:15 AM
EPP's Avatar
EPP
If you manage to keep the inlet air temps down, and you don't get any knock, then you can run a lot of boost with a 9.9/1 compression ratio. Bob
