Hot part clearance
Old Nov 5, 2006 | 09:33 AM
FastKat's Avatar
Default Hot part clearance
How much clearance do I need between my hot parts and painted parts on my engine bay? How about plastic parts, like my power steering resevoir? I was planning on ceramic coating them but I'm not sure how much that will really help.
Thanks -Dave
Old Nov 6, 2006 | 01:56 PM
FastKat's Avatar
Little help!
Old Nov 6, 2006 | 02:26 PM
KAOS's Avatar
3/8s , maybe. i had less than that in some areas on my old turbo setup and i never had an issue
Old Nov 6, 2006 | 02:33 PM
FastKat's Avatar
Wow, so about 3/8" away from painted steel and plastic parts? I'm a little close to my power steering resevoir... I don't want to look like an a$$ and melt a whole in it.
Old Nov 6, 2006 | 02:51 PM
SleeperZzZ28's Avatar
header wrap it
Old Nov 6, 2006 | 02:53 PM
obZidian's Avatar
coating should help.. and if you feel the need, just wrap a section of it. I dont think you'll run into any issues though i dont know exactly how your pipes are routed.
Old Nov 6, 2006 | 03:06 PM
FastKat's Avatar
I should have taken some pictures...
I have a set of C6 LS2 Covette manifolds flipped upside down, dumping up and slightly forward. I am using a 90 degree bend and some straight pipe to come around the engine in front of the F-body accessories. My driver's side pipe gets close to the power steering reservoir.
I am going to use a ceramic coating, just not sure if that will be enough?
Old Nov 7, 2006 | 08:12 AM
fitz98ta's Avatar
i have my hot parts coated and in a couple places they are VERY close to painted parts on my car and no problems, i would say wrap would do as good if not better also (but remember wrap will add to the overall diameter)
