Question about parasitic loss with centrifugal sc
Wondering about something. How much horsepower does it take to drive the average small centrifugal sc that is capable of maybe 450 or 500 hp? Thanks.
I was looking at driving one with an electric motor and the best I could find was with a paxton industrial blower air knife (you cand find them on the web)
aprox. 20 hp will make about 3.3 psi at about 900 cfm. I did some exp. on my owen and with a powerdine blower. riged and I do mean riged up with 3 electric motors 2 5hp 1 3hp I could spin it up to aprox 18k rpm and make about 6 psi. that was with the outlet choked down I have no idea obout the cfm.
Thanks, that's exactly what I'm thinking of doing, although probably in a much different application than you had in mind. I'm thinking of building my own frame and powering it with a small supercharged engine. Probably a 4 cylinder from a car, because of the easy availability of transaxles. Maybe a bike engine if I can find a way to connect it in a rear wheel drive configuration.
The reason I am thinking of driving it electrically is because I can vary the speed of the motor independently of the speed of the engine, which would give me the ability to have a fully customizable boost curve.
Now, once I figure out for sure which engine I'll be using, I'll just need to find out its air consumption rates so I can know how many cfm I'll need to reach a given power level, which will let me know what size motor I'll need.
Since it's custom, I guess I could modify a v6 blower with it's own mount. It might even be easier, since I could use the existing intake. I'd just rather have the efficiency of the centrifugal, since I'll be trying to make a high hp/liter ratio and don't really need to add anything that would detract from it's potential or reliability. It'll be near the ragged edge anyhow. Turbos are out, because I don't need boost coming on suddenly in a curve.
I just found this.
http://auto.indiatimes.com/articlesh...,prtpage-1.cms
To get to the part that applies here, you have to get past the pro-turbo theme of the article. Nothing wrong with that, it just doesn't relate to this thread. He gets into some math formulae that can answer quite a few questions. If you can force yourself to use them, that is.
Originally Posted by brad8266
Run an inline 6 cylinder with a blower. ![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
![Headbang](https://ls1tech.com/forums/images/smilies2/headbang.gif)
