View Poll Results: What Transmission set-up?
Voters: 179. You may not vote on this poll
What transmission would you go with for my Twin Turbo set up?
#41
from what i've been reading, most street strip turbo guys with th-400's have been running very tight stalls like 2800 ish. All of the torque from the turbo makes them actually stall much higher however. I'm thinking the 4l80-e is def a better trans for what i want being mainly a street car. Thanks for all your input fellas! So far I've gathered that i will need the 4l80-e trans, converter (looking at around 3000 stall), new driveshaft, longer dipstick (Can i use the longer dipstick that people use in the TH-400 swap?) Flexplate, crossmember, and wiring harness. There may be some other odds n ends but from what i've gathered, i think this is the jist of it. Thanks a lot ObZidian, you were a huge help!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
#43
Coal Mining Director
Use a 2600rpm stall IF you go with a transbrake. No transbrake = bigger stall.
#44
Originally Posted by obZidian
as i wasn't suggesting that you implied that. My implications were to superman, who feared that a 4l80e swap would require "hacking" Which of course isn't necessarily true. Thus, i was just proving that to get a 4l80e, mod wise, is not as involved as anyone might think.
However, if your imply that a simple BFH mod, like the one that is needed to fit 315, is enough to make you choose between these two trans, then, well, i believe we are completely different people with different levels of mojo.
Its our choice, we should be all wise enough to scale the differences and make and educated decision. I felt that the 4l80e is a wise trans choice, as you feel the th400 is.... but to say that one is "better" than the other becuz it will not require you to actually lift a rubber mallet and massage your trans tunnel a bit, besides your other points you had mention which i do agree with and see your point, well; to me, that isn't a viable difference that will weigh enough to tip the scales. IMO of course!
I did not pick up that you referenced another poster. My bad.
Seems as though we agree about that. I see your point, too. I would like an OD, but the expense (read here that I'm cheap) didn't warrant it for me. Wish I had deep pockets like you, because I would have gone 4L80E.
SC-
#45
deep pockets? Hmmm.... i wouldn't say i have deep pockets, more like a shallow bowl but with a BIG SPOON. lol
No worries dude, really, i understand that the 4l80e will require more cashola but to me, its well worth it, well, sorta! You have a decent setup there so we're not so far off.
superman, no worries mang, give a hola anytime, i believe you got the jist of it. A transbrake is a great idea as well, looking to get one as well.
anyways, good luck. Mine is going in shortly. I'll get you some pics and a link to the thread if im not to lazy to actually start one.
LAterZ!
LAterZ!
#47
thats still a thought except for the fact that i cant drive worth a damn, haha
__________________
#48
im going to be one of the few and say get an M6. if you wanna do stop light to stop light racing then go for the auto's but for little rolls (40+mph) go with an M6. soooooo much fun.
thats just my $.02
thats just my $.02
#51
I took the plunge and got a TH400 with all the goodies including a t-brake. My car is by far no daily driver. I figure since it has no AC or heater then it doesn't need OD. Now I have to pick a stall and rear gear ratio for the 9 inch. I am thinking a 3000 stall and 3.50 gear. Any suggestions? I will be running a 325/50/15 DR.
#52
Originally Posted by FUroundeye
You'll have to hack up the car for the TH400 just as much as the 4L80E, so...
#53
Originally Posted by V6 Bird
Really...what do you have to hack up...I need to know so when i put the T400 in again it fits right.
#55
well, superman, you could go M6 if that is what you really want? Its really not a matter of not knowing how to drive it, but how many hours you spend in it to figure it out.
Manual is fun, but dd it, well, here in miami, it got old in my DSM's and in my old CTS-V..
alot of fun though when you get open road. Also, textralia all the way!!
#56
right now its either 4l80-e or M6 here.... 4l80-e would be with a nice yank 3000 or 3200, m6 would be with a textralia for sure
__________________
#57
7 Second Club
#58
I decided to give Prefomabuilt (SP) a shot on the verter. I am gonna go with a 3000 stall in the TH400. I will be running 325/50/15 DR's. I have t decide on a gear for the 9 inch now. Thinking a 3.50 would be nice.
#59
if this car will see 80% street then get a 6speed with 3.50 gears...
__________________
i agree if drag racing at a track is the main purpose of the car, for sure go auto, but if its a car you like to drive all day and cruise at 80 go stick.......by the way has anyone concidered doing a liberty manual, with that torque converter set-up that the 5.0 and mustany drag racing guys are using.......... best of both worlds but a think its a $10,000 dollar set-up? but hey...its only money
__________________
#60
Senior Member
Originally Posted by smokinHawk
two questions for you
1) do you want to go fast
or
2) do you want to break trannies?
Th400 if you chose #1
or
Havent 6 speeds went 9s? I vote 6 speed. Good milager still with 6 forward gears, fun to drive, pick your own gear, etc...
