Fan settings
Old Nov 12, 2006 | 08:16 AM
tici's Avatar
Default Fan settings
What are you FI fan settings?
Mine are:
First stage ON = 219
First stag e OFF = 212
Second stage ON = 227
Second Stage OFF = 220
Maybe too high, but this is a daily drive and I don't want to run too cold.
Should I install a fan switch for the "crazy moments" or set lower ON/OFF settings?
Old Nov 12, 2006 | 10:43 AM
TS6's Avatar
TS6
You want it lower. FI is more detonation prone and lower coolant temps will help prevent detonation. I wouldn't worry about running "too cool", most of us have enough trouble keeping them from running too hot!
Old Nov 12, 2006 | 04:26 PM
tici's Avatar
Is that a problem to run the fans constantly?
The original Vortech settings are:
First stage ON = 193
First stag e OFF = 187
Second stage ON = 200
Second Stage OFF = 193
this for the stock 'stat. A little strange, isn't it?
Soo... how have you set them?
Old Nov 13, 2006 | 07:53 AM
Country Boy's Avatar
Senior Member
I have my pushers set to come on at 175, but I have a 3rd fan that on a switch for the "just in case". I was still running too hot with my 2 pushers in hotter weather.
