what size twins?
Old Nov 13, 2006 | 10:01 PM
datsbad's Avatar
Default what size twins?
Guys I posted a what size single question last week but now my customer has changed to a twin. what size twins would give me 800 rwhp good low end and be capable of 1000 hp ?
this is on a stock cube LS1 ?
Thanks again !
what flange and exhaust housing also ?
Old Nov 13, 2006 | 10:50 PM
TrakDay's Avatar
Twin 67s... I am no pro, but I would assume they would get you there.
Personally going twin GT42Rs on my 408, but I need a bit more power to get my pig moving.
Old Nov 15, 2006 | 09:43 PM
datsbad's Avatar
67's really? I was thinking smaller. I would want full boost by 3500-3800 rpm
Old Nov 15, 2006 | 09:53 PM
TrakDay's Avatar
Ok... well how about twin GT35Rs then!
Old Nov 15, 2006 | 09:54 PM
SSilverSSurfer's Avatar
TIAGO has twin 70's on a stock cube and is @1000hp...he posts on here im sure he'll chime in
Old Nov 15, 2006 | 09:55 PM
datsbad's Avatar
I got to say I am not up on the turbo sizes and all . There are way to may for me to learn that quick !
Old Nov 15, 2006 | 10:04 PM
if you go to the forced induction.com website, they have a terrific turbo chart that explain everything,
Old Nov 16, 2006 | 07:41 AM
sr71's Avatar
I had T61's on my stock cube engine. with p-trim exhaust wheels and .68 ar t-4 housings, it made full boost at 3800.
Old Nov 16, 2006 | 08:38 AM
smokinHawk's Avatar
if your only wanting 800rwhp and spooling early, something like a gt35 or smaller then a 60mm (like 58-60mm)
i think the high output incon turbos could do 700rwhp (gt28 hybrids right) so something a little bigger then that.
Edit: missed the part that you wanted to be able to hit 1krwhp so youll have to use something bigger then a 60mm like Harlan ays below.
Old Nov 16, 2006 | 08:52 AM
y2khawk's Avatar
How high does he plan to spin it?? That will dictate turbo sizing as well.
Mid 60 mm minimum if he plans to hit 1K RWHP. Even a pair of 67's will be working pretty hard at that point, you'll trade spool for efficiency though.
70+ units will be a little lazier, but you'll make more power with them just keeping the charge temps down.
been there, done that
Old Nov 16, 2006 | 11:03 AM
AVB's Avatar
AVB
Here's a graph from another forum member running a couple Precision T44's which were modded to T52's (i think) on a top-mounted setup, stock cubes..
Looks to be ideal to me!!
Arnel
Old Nov 16, 2006 | 11:18 AM
DrTurbo's Avatar
LS1TECH Sponsor
Arnel
Those were the units I believe Jose and Jason customized for Nick Y. in his C5 auto Vert. Those turbos went 9.9's@145+mph on regular wheels.....amazing. Now Jose built him some new custom ball bearing units that are even larger that spool the same.......should be a wicked setup.
Old Nov 16, 2006 | 11:20 AM
DrTurbo's Avatar
LS1TECH Sponsor
Go with a set of T61 DBB's. We have had good sucess with them on our customers cars. Same as a GT35R but without the price.
Old Nov 16, 2006 | 11:34 AM
TrakDay's Avatar
Welp... there you go!
Old Nov 16, 2006 | 11:41 AM
AVB's Avatar
AVB
Are those the Turbonetic units that Nick just swapped to? If so, I just got my set yesterday and installed them last night!!! Anyways... that graph is Kevins.
Arnel
Old Nov 16, 2006 | 11:51 AM
DrTurbo's Avatar
LS1TECH Sponsor
Yes, he went to a set of T-netics that Jose had speced for him. Looks like they will be killer units.
