Measuring blower speed
Old Nov 16, 2006 | 12:48 PM
stevieturbo's Avatar
Default Measuring blower speed
Anyone ever hooked up something, to measure the rotational speed of their blower pulley ??
basically, to allow you to determine the amount, if any, slip you are having in your blower drive system.
It can be using you ecu, or a simple in-car guage. Doesnt matter.
If you have...how did you do it ??
Old Nov 16, 2006 | 01:03 PM
kp's Avatar
kp
drill a hole and epoxy a magnet in the pulley, pick up an inductive pickup and use the speedo input of the stock PCM and log it. You would have to add a few magnets and figure out the ratios but it would probably work.
I use the front ABS sensor to work my speedo now, just had to play with the numbers some to get it accurate.
Old Nov 16, 2006 | 01:08 PM
andereck's Avatar
Yes, do you have an external data logger than can accept a frequency?
There are several ways to do it, I am using an infrared sensor mounted to the blower and aligned to see light reflected from a stripe painted on the blower pulley.
Here is a link to the sensor:http://rocky.digikey.com/scripts/Pro...V=46&M=QRB1134
Basically you're creating a tach signal to be read by your logger.
Another way is to use a hall effect or VR pickup with a magnet or stud mounted to the pulley. The hall effect sensor is not reliant on rpm to create voltage, nor would it be affected by dirt or dust on the pulley as the optical sensor will be.
Old Nov 16, 2006 | 03:24 PM
I do have a spare wheel speed input on my ecu, which will run a hall sensor.
For 1 revolution, it expects a minimum of 4 teeth, although this shouldnt be a big deal. If I used one tooth, "speed" would just be 1/4 of what I see on the computer.
If I baseline at 1000 engine rpm I could get an easy reference to see if blower speed rises in a linear fashion with engine speed.
