Anyone ever seen this bracket b4?
Old Nov 21, 2006 | 08:05 PM
BigBenz's Avatar
Default Anyone ever seen this bracket b4?
Hey guys i need some help. I just bought this D1sc kit and i need a few things. First i need a idler pulley for the mounting bracket. Its a solid steel bracket. I pulley is 3x1 1/2 inches and its plastic. I cant find a pulley for it anywere. I think its made by SDCE ( thats what Bob at epp told me) I know the blancer pulley is made by SDCE. I need a harmonic balancer bolt for the large 8 rib pulley in this pic. If anyone has any ideas as too what size of bolt i need or were to get the pulley from please let me know.
the bracket its for a D1sc kit for a 2000 z28 camaro.
Thanks.
Old Nov 21, 2006 | 09:33 PM
BigBenz's Avatar
if i use a same size opulley but it has ribs on it will it destroy my belt? My stock 12lb pulley is the same size as this one. Im just wondering if it needs a smooth serface on the back side of the belt. Because it is a idler pulley.
this thing is killin me
Old Nov 21, 2006 | 09:46 PM
frcefed98's Avatar
Should be able to find the idlers at NAPA or autozone, checker etc...
A NAPA DC will stock damn near any idler you'd want....use to work at one a long time ago...
J
Old Nov 21, 2006 | 10:06 PM
BigBenz's Avatar
cool ill have to try napa. how about the bolt? Any idea on size?
Old Nov 21, 2006 | 10:15 PM
frcefed98's Avatar
Crank bolt? Should be able to order one from Bob@EPP or from SDCE....or even ATI themselves.. I can't remember the thread size for the bolt...M16-20mm or something like that...probably way wrong on that so call up Bob or SDCE.
J
Old Nov 21, 2006 | 10:19 PM
frcefed98's Avatar
OK yep I was pretty close, specs on a stock crank bolt are
The bolt you need is a 16mm / 2.0 thread pitch and 120mm in length....so something a lil longer...125-130mm???
Old Nov 21, 2006 | 10:28 PM
BigBenz's Avatar
nice ill see if napa has that pulley
thanks alot man
Old Nov 21, 2006 | 10:37 PM
frcefed98's Avatar
Tell em to look in the "tem" book( a/c parts catalog ) if the computer fails to cross reference it....they'll be reluctant but push em to work for their $$
J
