turbo on a sbc question??
Old Nov 22, 2006 | 12:31 PM
whitetopz28's Avatar
Default turbo on a sbc question??
hey guys wasn just wondering how much power i can get out off a 2-bolt sbc motor.. planning on putting one on mine but dont want to over boost it??? thanks
Old Nov 22, 2006 | 12:57 PM
sb427f-car's Avatar
SSU'S Vice Mod
Ewww, 2 bolt main? Do you just have a 2 bolt block laying around????
Old Nov 22, 2006 | 01:04 PM
WheelsUp84z's Avatar
do the splayed 4 bolt conversion, should be just as strong, if not stronger than a regular 4 bolt, and boost away
Old Nov 22, 2006 | 03:48 PM
pwrtrip75's Avatar
the big 2-bolt, 4-bolt hype is all over rated.
Old Nov 22, 2006 | 11:29 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I had a 350sbc built for a lot of procharger boost, and had a choice of old blocks to use. The builder at the machine shop preferred that I drop off a 2 bolt block to convert to a splayed 4 bolt, saying it would be stronger than a factory 4 bolt.
Old Nov 23, 2006 | 01:13 AM
KissMySSo1's Avatar
has anyone ever heard of a motor failing because of a 2 bolt main cap failure? because i certainly havn't. i'd like to see one tho if there is any.
Old Nov 23, 2006 | 06:57 AM
chuntington101's Avatar
there was a guy on the mustang forum a while back trying to build a very budget twin turbo. he used a four blot fist and got over 600rwhp form that. he then decided to use a BONE STOCK 2 bolt block and got over 500rwhp i think.
you could always just try it! if you cook the block then you can always upgrade to a aftermarket one or find a 4 bolt one
thanks CHris.
Old Nov 23, 2006 | 08:32 AM
QSPres's Avatar
No matter what you use, the main caps are going to walk with big boost.
I'd use the 2 bolt block, with the splayed cap mod, and use bigger/longer dowels to help keep them still..
Old Nov 23, 2006 | 09:52 AM
engineermike's Avatar
Breaking the caps is not the issue, cap walking is. With 4-bolt billet steel caps, mine still walk and fret the block at 16 - 24 psi boost. I've heard of main bearing failures and cranks breaking due to cap walk because the mains are no longer aligned if the caps are moving around. I would be scared to see what would happen on my motor with 2-bolt mains since they walk so much with 4-bolts. A local guy with a 2-bolt BBC and nitrous had his walk so much that they welded themselves to the block.
Mike
Old Nov 23, 2006 | 03:31 PM
KissMySSo1's Avatar
i have always heard the 2 bolts converted to splayed 4 bolts are the strongest way to go.
Old Nov 23, 2006 | 04:01 PM
Dragframe's Avatar
thanks CHris.
try over 660 hp at the wheels on a stock shortblock
http://www.turbomustangs.com/smf/ind...?topic=61219.0
Old Nov 23, 2006 | 04:18 PM
i stand corrected
Chris.
Old Nov 23, 2006 | 08:09 PM
. . . and this is a quote from the guy.
"I think it may be severe crank distortion and cap walk chewing on the main bearings a bit. . . . I pulled the pan and looked at #2 and #3 mains. They are down to the copper . . . The crank is smooth but the main bolts were kind of loose and the caps were walking around quite a bit and fretted the block a fair amount . . . Only the cap walk tells the story."
I wouldn't really call this "holding up to the power."
