A2W Intercooler In A Daily Driver?
Old Nov 29, 2006 | 06:24 PM
XpEdItIoUs's Avatar
Default A2W Intercooler In A Daily Driver?
Just like the title says, dose anyone have a air to water intercooler in a daily driver. Pictures of setups would be nice.
Old Nov 29, 2006 | 07:56 PM
2001-WS6's Avatar
The guys driving the TTi Race Kits do. I averages 3 days a week this summer making 40 mile round trips on the street and highway between the house and work. Then plenty of cruising and testing on the street.
A properly sized A2W is plenty streetable and my car has never run into temp issues when the opportunity to enjoy playing around on the the street presents itself.
Rick
Old Nov 29, 2006 | 08:03 PM
XpEdItIoUs's Avatar
Rick
What size is your intercooler? Do you fill with ice before you drive anywhere? any pictures of your setup?
Old Nov 29, 2006 | 08:14 PM
2001-WS6's Avatar
I don't remember the size of the intercooler but I'm guessing its rated in the 900hp range. The water tank is probably 1.5 gallons and it uses a nice radiator/fan setup to cool the returning water.
I don't bother running ice on the street. The system manages what you need to have for playing around on a warm day really. Runing the water pump and fan will cool the water back down nicely after playing around in traffic. If you have clear air cruising on the freeway you don't even need to run the fan really.
The track is certainly where it shines though. You can fill the water tank with ice and have bath tub warm water on high 9 low - 10s pass on a 90+ degree day. Drain tank and toss in another two bags of ice and go play. You might see your IATs run up 15-20 degrees over ambient on a 95 degree day when the ice is in there. If you toss meth in there you're looking at winter air where ever you race.
Rick
Old Nov 29, 2006 | 08:52 PM
XpEdItIoUs's Avatar
Rick
That's just what im looking for, Im planing on making a custom air to water intercooler kit but I have no idea where to mount it and where to mount the water pump. Any pictures would help me alot.
Old Nov 29, 2006 | 08:55 PM
SuperZ's Avatar
Look on TTi site or on Mightymouses sight.They list what kinda of A2W it is.I believe its a precision
Old Nov 29, 2006 | 09:07 PM
koolaid_kid's Avatar
Where did you place your intercooler?
This is an interesting setup if the battery does not to be moved.
Old Nov 29, 2006 | 09:24 PM
Murdock's Avatar
TTi race kit puts the water tank in the stock batt location, with the batt relocated. MECHAM changed his kit around and put the tank in the spare tire well, leaving the batt in the stock location.
Old Nov 29, 2006 | 09:32 PM
otherwhitemeat's Avatar
i got a custom set-up where the 9 gallon water tank is in the trunk, and the spearco intercooler is in the left front corner of the car behind the bumper cover and the water pump is mounted under the trunk floor, but you can mount that anywhere in line.
Also i use garden hose to run the water, like the soft rubber kind, with barb fittings. But you can use whatever you want. IT IS FOR SALE IF ANYONE IS INTERESTED!
IT ALL FITS NICE WITH MINIMAL FABRICATION
Old Nov 29, 2006 | 10:49 PM
Nine Ball's Avatar
LS1Tech Co-Founder
All Magnachargers have an A2W intercooler on them. They are some of the most reliable supercharger kits out there.
Tony
Old Nov 29, 2006 | 11:00 PM
XpEdItIoUs's Avatar
Tony
Can you post some pictures of your intercooler setup, I just want to some ideas on where to mount it.
Old Nov 30, 2006 | 08:39 AM
ls1290's Avatar
Dumb Ass Vette Moderator
What do you think of this A2W cooler? The core is 9" x 10.5" x 4.5". The water fittings are 3/4" NPT.
Keith
Old Nov 30, 2006 | 09:26 AM
XpEdItIoUs's Avatar
Thats the ebay one, That should work on a 600hp car easily.
Old Nov 30, 2006 | 12:39 PM
FormulaFire's Avatar
What A2W intercooler would be good for a 1000hp car? How hard is the plumbing?
Old Nov 30, 2006 | 01:07 PM
ls1290's Avatar
What about 1200 as advertised?
Keith
Old Nov 30, 2006 | 03:26 PM
XpEdItIoUs's Avatar
Keith
I don't know about that unless someone making 1200 hp test it.
Old Nov 30, 2006 | 03:45 PM
my intercooler looks the same as the one above, but one air openning is on the top, and its not a cheap unit! its a spearco unit, new $1100, and it is perfect for up to 1200hp applications
Old Nov 30, 2006 | 04:08 PM
1a-play's Avatar
what water pump is used
Old Nov 30, 2006 | 04:55 PM
i use a marine sump pump, it flows a ton and is very good quaility, you can't even hear it run!
Old Dec 1, 2006 | 08:36 AM
ls1290's Avatar
OK, what is the difference between the spearco one and the ebay one. They both look the same and have the same specs as far as I can tell.
Keith
