What turbo would you recommend for a 364?
Has Unresolved Sales In Feedback/12 second club
Im trying to figure out witch turbo to use with my stock cube 6.0. I was thinking a GT66 off of ebay, but im not sure if it would be big enough for my application.
Yeah I would definitely go bigger then a 66. At least a T76 preferably w/ a GTS wheel. I'm going with a S76 but if you are stock bottom end/stock CR and are only going for 8-10psi the S76 would be overkill I think. Get a nice flowing 76 and you will have no problems!
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Originally Posted by SSblack98
Yeah I would definitely go bigger then a 66. At least a T76 preferably w/ a GTS wheel. I'm going with a S76 but if you are stock bottom end/stock CR and are only going for 8-10psi the S76 would be overkill I think. Get a nice flowing 76 and you will have no problems! ![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
2003 6.0 Lq4
Stock Rods
Stock Pistons
Stock 6.0 Heads with springs.
Originally Posted by notatruews6
Ill post up a little more information about the motor.
2003 6.0 Lq4
Stock Rods
Stock Pistons
2003 6.0 Lq4
Stock Rods
Stock Pistons
If your going to stick with a stock motor and keep it that way id go with a 76mm turbo..... if not then id go bigger so your not buying the same thing twice... ie the turbo.... you can always buy the bigger turbo and just run 8 psi with it......
Do you plan to run stock springs on those stock heads?????
Kyle
