Muah Hahahahah...!
I agree with ya there...... my 1st session was crap... as soon as HP started to climb with boost id start to spin on the rollers.... 2nd outing was much better.....
Damn John..... 25psi..... i wonder what mine would do with 8 more psi...... mine did the 842rwhp @ 17 psi....
Is there much more then 25psi left in that turbo????
The 408 should help spooling quite a bit....
Now while cruising.... as soon as i hit it im in boost and it moves so fast i never have time to watch..... i have to watch the road LOL
Unlocked A3.
I'm not sure what your car would do Kyle, it's hard to compare really. You have more cubes and more compression and that probably equates to a couple lbs of boost.
Yeah it does...... the chute needs to go on the car before the spring.... I plan to turn it up.... PSJ and I are going for a certain ET
Did you run slicks on your dyno runs? Oh and I am running PP Gold springs... My CR is just over 8.1:1... I want to take it a little slow with the tuning and check back pressure as well. The bad thing is I am just running out of time before I have to leave for Iraq.
