Exhaust temps STS
Old Dec 20, 2006 | 01:25 PM
Got Me SOM's Avatar
me and red supra talked about this last night. pretty cool what you learn in school can apply to your hot rod.
Old Dec 20, 2006 | 01:30 PM
great421's Avatar
Default Another Engineer!
Praise God!
Another Engineer!
Maybe YOU can speak to some of these 19 YO "I know everything because I've been posting every day for the past 18 months just to hear myself speak / Don't confuse me with the facts, I've already made up my mind" cyber racers and break thru their preconceived notions and errors in logic.
Than again, maybe not, they are afterall 19 YO males...
Anyway, "Nigel" - I have 2 custom license plates on my Michigan vehicles I thought you'd enjoy:
GOES2XI - 96 Formula
1LOUDER - 75 Lemans
MIKE
Originally Posted by NigelTufnel
Simple Thermodynamics. PV=nRT.
V is the volume the gas occupies. In an exhaust system, that volume is defined by the exhaust pipes. Thus, in an exhaust system, V is constant.
Without getting into detail, n (# of moles of the gas) may be considered constant.
R is the ideal or universal gas constant (i.e., another constant).
Thus, the only variables are P and T. As temperature (T) of the exhaust gas increases (or decreases), the pressure (P) exerted by the gas also increases (or decreases). The higher pressure gas results in a higher gas velocity. This higher pressure (and higher velocity) results in shorter spool time relative to colder exhaust temperatures.
Old Dec 20, 2006 | 01:38 PM
Zombie's Avatar
Spinal Tap?
Old Dec 20, 2006 | 09:17 PM
great421's Avatar
Default Not Spinal Tap, "The New Originals"
Originally Posted by Zombie
Spinal Tap?
Or maybe "The Lovely Lads", quite possibly "The Thamesmen" though.
Yes! Spinal Tap.
"Nigel Tufnel" (a.k.a. - Christopher Guest) was / is the lead guitarist. I guess he likes to go fast too...
"This one goes to Eleven; that's one louder isn't it?"
MLE
Old Dec 21, 2006 | 09:08 AM
NigelTufnel's Avatar
Yes! Spinal Tap.
MLE
LOL! Another Spinal Tap fan I presume???
I put the STS kit on my C5 (6spd) and it went "one louder" too, and runs in the "elevens". Hoping to get into the 10s next year. I just installed an x-pipe (cat-less) that was HEAVILY wrapped to try and minimize heat loss before the turbos. Also getting a new clutch (stocker couldn't handle the abuse at the track) and some decent rubber this winter.
Old Dec 21, 2006 | 10:21 AM
great421's Avatar
Default New Clutch (SPEC 3+)
You are correct; since you're from Ohio, feel free to use either of those vanity plate choices too! I had a guy at work (Ford) read my plate "1LOUDER" and just laughed out loud: "I love that movie!"
My clutch of choice is the SPEC 3+ (get the plus version - KEVLAR is your friend!); with the addition of that clutch, I was able to break my 10 bolt ring and pinion on the street with street tires! First try (Doh!) Anyway, it grabs, and the next "weak link" was exposed.
10s!?!
I wanna be YOU when I grow up! My Formula went 14.41 w/o the STS, I haven't had it to the strip since the install, but it sure is alot quicker!
My brother's 04 GTO no longer makes me look silly! His is 100% bone stock (not even a K&N), and he runs 13.8s all day long. I'm just guessing, but I'd venture mine runs 12.9s now...
Right now, however, with the rear end out, it doesn't go at all!
MIKE
Old Dec 21, 2006 | 10:39 AM
koolaid_kid's Avatar
Absolutely. Amazing what you can learn in physics class if you decide to stay awake and pay attention. I never thought I would see the word moles used on one of these forums.
What I would like to see are the before and after hp/tq figures. My system will get wrapped next year, for certain.
BTW, you sure does talk fancy.
Old Dec 21, 2006 | 10:44 AM
Praise God!
Another Engineer!
MIKE
Now that's funny. I suspect it may not work, I usually try once then shrug my shoulders. I suspect that engineers are treated the same way we are at parties. People are interested until you tell them what you do. Then they say "Oh" and quickly find a way to exit stage right.
Old Dec 21, 2006 | 10:52 AM
Zombie's Avatar
Avoid spec like the plague, they make junk clutches. I was going through a clutch every 1000 miles. After the 4th spec that was in their died I gave up. Instead of paying $1500 for a clutch that "might work" I swapped to a th400.
My rear mount turbo times are in my sig.
Old Dec 21, 2006 | 11:55 AM
great421's Avatar
Default One vote NO on SPEC 3+
Rob (I presume, hence the "Zombie" name) -
I'm sorry you had several problems with your SPEC clutches. Did you ever find an acceptable clutch manufacturer? (BTW - I still love mine; I'd rather find a good clutch than go automatic!)
MIKE
Old Dec 21, 2006 | 12:02 PM
great421's Avatar
Default 19 YO males
Like I said: "Don't confuse me with the facts, I've already made up my mind!"
I actually remember being like that, but I don't look back with pride, rather shame and disgust that I could be that kind of (know-it-all) kid. But, that was 21 years ago; I've learned a bit more information (and humility!) in the last 7700 days!
MIKE
Old Dec 21, 2006 | 12:21 PM
  #32
Well, I also remember that the older I got (after turning 25) the smarter my dad got. Guess it's all part of the growing up process.
But back on topic, has anyone done a comparison of the 1/8" thick wrap versus the more common 1/16" wrap?
Clearly, the 1/8" will hold in more heat, but what is the percentage gain of it versus the 1/16"? I will probably go 1/8" since the cost differential is slight, but it would be nice to know that it is the correct decision and can be justified with data.
Also, has anyone used the HT silicone coating? Were you pleased with the results and how many cans did it take to go from the y-pipe to the turbo?
Old Dec 21, 2006 | 12:50 PM
  #33
MiketurboLS1's Avatar
Will increasing the exhaust temps. have a dramatic effect on intake temperatures? or would it be negligible? I see how insulating the exhaust pipes will retain heat and increase exhaust pressure, which will also result in heating up the exhaust turbine. just curious to see what the effects would be on the intake side.
Old Dec 21, 2006 | 01:12 PM
  #34
It would have no effect at all. The two sections are completely separated. What it will do is increase the efficiency of the turbo, resulting in a power increase. Which is probably why you went with FI anyhow.
What it will not do is make the butt turbo as efficient as a front mount. Some heat loss must occur, just because of the distance the exhaust must travel to reach the turbo.
Old Dec 21, 2006 | 01:22 PM
  #35
LastBlack02SS's Avatar
Could someone provide me with the best online place to get exhaust wrap, a reccomendation of how much, and what type to get? It would be much appreciated.
Old Dec 21, 2006 | 01:32 PM
  #36
Google on "exhaust wrap" and "exhaust wrap kit". A kit includes the tie wraps (required) and the HT silicone spray (is this required?).
Also, eBay carries it too.
Most sites seem to think that 100' of 2" wrap is enough. Can someone who has done this chime in?
I am going with the thicker wrap, just because.
Old Dec 21, 2006 | 01:40 PM
  #37
Zombie's Avatar
MIKE
Nope, no reference to music in my name. I've been known as Zombie for the last 13 yrs LOL Goes back to some questionable computer activities I did as a kid.
I've heard that mcleod is decent and seen more people have success with them vs other brands, but i've still seen several posing about problems with them. I feared the automatic at first, now people fear my auto
For a turbo f-body it doesn't get much more fun than a RMVB th400 with transbrake. I was a die hard 6spd fan until the conversion, this setup OWNS the old 6spd setup for fun, especially on a highway roll.
As for insulating the exhaust, the better you insulate the better the turbo will spool. I tried a .96 a/r housing on my setup but it doesn't work as well as the .81 a/r I had on there so i'm swapping back. I'm going to try and insulate as much of the over the axle pipe as I can when the turbo comes off again. My y-pipe is insulated with 1/2" ceramic fiber.
Old Dec 21, 2006 | 02:00 PM
  #38
So the exhaust housing and compressor housing are completely separated from each other now a days? and here i thought they had to be connected somehow. and also that increasing the temperature of the Exhaust housing will have no effect on the temperature of the compressor housing??
Old Dec 21, 2006 | 02:11 PM
  #39
O.K., let me restate. You will probably see more effect from the ambient temperature change than the change of the exhaust gas temperature. Think about front mount turbos, do you think that the fact that they have even hotter exhaust gases affects the temp of the intake air? If that were true, butt turbos would be preferred.
So I would restate as "the effect would be negligible, at best, and the tiny increase, (if any) would be far outweighed by the increased efficiency.
Think of it this way: the intake impeller can be thought of as a large fan. Fans cool. If you can provide data that it has an effect, O.K. Otherwise, please keep sarcasm in PMs and do not cloud technical discussions with it. No one appreciates it, and it shows your appreciation of this forum.
Old Dec 21, 2006 | 02:39 PM
  #40
I appologize koolaid, with all due respect i did ask a technical question and didnt exactly get a technical response in return, but again i do appologize....I understood the concept of increasing heat, to increase pressure which will result in a more efficient turbo. My question was about intake temperature which you did answer, im just curious as you are to what the data would show in the relm. I dont totally agree on the intake impeller, i do see where your coming from but piece of metal spinning at a 100,000 rpm will generate some heat, otherwise there would be no need for intercoolers or meth injection. Maybe someone else can chime in on this subject
