Exhaust temps STS
1. Exhuast Manifolds 380-400*
2. Top of Cat 400*
3. Outlet of Cat 525*+
4. Y-Pipe joint 450*
5. Half way down I pipe 250-300*
5. Over Axle pipe 180-225*
6. Turbine housing 380*
7. Muffler after turbo 300*
8. Exhaust tip 280*
9. Exhaust gasses leaving tip 330*
I'm going to wrap my exhaust with 2" heat wrap from the y-pipe to the turbo
this week. I'll re-check temps for comparison. I'll also be going back for a new dyno tune with a two bar map sensor. Maybe I'll do a run where the only change is heat wrap. Has any one else got solid numbers to back up wraping the exhaust. More Hp more tq or earlier spool? I know a lot of people have tried wrapping the exhaust but I wasn't able to find any REAL numbers.
Jared
So i was taking my Y and I pipe off so I could wrap them. I've had a little rattle for a long time and I thought it was the valvetrain. Nope my drivers side cats gone loose. Its not broken up or setting any codes but the honeycomb is loose
. Any one try to get the extended emmision warranty replacement of thier cats with a rear mount turbo and wrapped pipes? Any body have an 02 low milage F-body drivers side cat laying around they want to get rid of cheap? Other than that the y-pipe back is wrapped except for the last foot. I ran out of wrap.
I used 100' of 2" wrap and need a few more feet. I'll get temps sunday but for now I'm done and time for a
I assume with the sts you should run it in the 200's?
After: second gear pull from a 15mph roll 7psi @3200 rpm
That is an outstanding 500rpm more that I'm now pulling full boost. I'm getting my 2.5 bar tune at Haddad wednesday and then hitting the track jan 13th so I'll try to get some numbers dyno and strip
anyone care to share info why keeping the exhaust temp as high as possible to the rear is important? does that essentially help exhaust flow?
More heat = more exhaust volume = less exhaust molecules needed to turn the turbine = less energy used = better effecciency = lower backpressure = less pumping losses = more power.
V is the volume the gas occupies. In an exhaust system, that volume is defined by the exhaust pipes. Thus, in an exhaust system, V is constant.
Without getting into detail, n (# of moles of the gas) may be considered constant.
R is the ideal or universal gas constant (i.e., another constant).
Thus, the only variables are P and T. As temperature (T) of the exhaust gas increases (or decreases), the pressure (P) exerted by the gas also increases (or decreases). The higher pressure gas results in a higher gas velocity. This higher pressure (and higher velocity) results in shorter spool time relative to colder exhaust temperatures.
