Biggest turbo/turbos for C5
I know the APS kit has twin 38's located where the cats were and are capable of 850rwhp on a 427.
Lets here some more
Next step is a GT3076R. 50lb/min each...max out around 850rwhp. Same power with the APS kit. More hp than most could ever use on the street....hook it and you'll go low 9's to high 8's.
Both turbos above are T25 turbines.
TTIx.....bigger exhaust turbines T3....Compressor side is triple secret so who knows where it will top out...probably +900 rwhp. Run 8's hooked.
Next step would be GT35R's. T3 turbines. 60lb/min
Easy +1000rwhp at 22psi.....run as fast as you're man enough to run.
Now I'm not that knowledgeable on the turbo sizing numbers when they have different letters and numbers unless they are using the same. So I don't know the difference between say one turbo using a T76 or one using say a GT35.
The GT35R's are the ones used by Speed Inc on the F-body Twin kit. Do they fit on the C5?? I assume in the same location as the APS kit
Oh and 850 is not the goal that is why
I dont know what size turbo's I have and to be honest I really did not care after finding out about other cars with the same kit. I only wanted 700 to 800rwhp. The car has far exceeded my goals. I will tell you that I was told the turbos each flow 55lbs/min. I am sure someone can figure out what size turbo's via that information...... There are guys already dyno'ing over 900rwhp with this kit. There is a company with the same kit with a modified exhaust setup going from the turbo's back with a 427ci and they put down close to 950rwhp on 12lbs of boost.. I think its Granatelli's 427ci TT car.
major spray (i know its a race motor) have made 1200 bhp i think with a 101 on a 427.
TTi are putting out big numbers. not sure the size of the turbos though.
APS kit (is it out yet?) uses Garrett GT 28r's i think. there are upgrades to GT30s i think which should puch you over 1000bhp.
PTK has made over 800rwhp on a 346 i think.
depends what you want really.
thanks Chris.
Pretty crazy looking at the pricing wars for the "elitist" vette crowd.
Dave
Guys, keep in mind when people talk about max numbers they are talking about what can be done with built motors, trick cylinder heads, appropriate cam, race fuel (usually), etc..
