help me decide On which on these blower cams
Old Dec 20, 2006 | 07:41 PM
Lawnboy's Avatar
Restricted User
Default help me decide On which on these blower cams
I am building a forged 346 with eagle H-beam rods and diamond -8.6 blower pistons for my 01 M-6 SS camaro.
It is only a street car, with a D1-sc twin intercooled Procharger system and Alky control Razor F-body methanol injection.
I am running Long tube FLP headers - Y pipe (no cats) to the stock SS 3" , duel -duel SLP exhaust system that came on the car since new.
OK i looked into the Thunder racing blower cam 214-230 601/575 lift on a 117 +1 degree. Thunder told me their cam is on there special lobes.
Also i was recomanded a Comp 214-224 585/563 lift camshaft on a 116 + 4 degrees with EX intake and XER exhaust lobes,
Lingenfelter has a 208-230 540/550 lift blower cam on a 121.
I am looking for something like these with very streetable manners and a close to smooth idle.
But i am confused about LSA and CL and Lobes and ramp rates.
I dont know if i should have it built on a lower CL to pick up more bottom end power, or to have it built on a higher LSA + CL to move the RPM power range up , to get more RPM out of her,
I been hearing that all the blower cames peak at 6,500 RPM anyway , i dont know how true this is
Please help ,Or let me know your combo and what cam your running
And if anyone is using any of these cams
Old Dec 20, 2006 | 09:41 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
How high do you want to spin it, and do you have any any hp goals or track goals?
Old Dec 21, 2006 | 12:33 AM
Lawnboy's Avatar
Restricted User
HI John
The car is a street car , maybe see the 1/4 mile 2-3 times a year , but really a total street car,
I dont think i will need to spin her past 6,500 RPM.
I am making 540RWHP now at 10 PSI on the stock motor, (stock heads stock cam, everything).
I am shootong for 650-700 after the rebuild, and ported heads , blower cam and more boost.
Old Dec 21, 2006 | 03:43 AM
LSs1Power's Avatar
Get the FM7 cam from Futral. Its great with boost and make tons of power under the curve.
Attached Thumbnails help me decide On which on these blower cams-stock-vs-8psi-run.jpeg   help me decide On which on these blower cams-dyno_feher_testing.jpg
Old Dec 21, 2006 | 09:26 AM
Lawnboy's Avatar
Restricted User
My friend has that cam, Its a little big for me i want something in the 214-224 or 216-230 range
just not sure on what lobe to but it on XE, XER, or the new XFI lobes ,
and also what LSA and CL to but it on, for my power range.
Help!
Old Dec 21, 2006 | 10:03 AM
98Z28MASS's Avatar
G5xb Ftw
Old Dec 21, 2006 | 10:16 AM
LS1Tech Co-Founder
What are the specs of the FM7, and why do you think it's too big, the lope?
Old Dec 21, 2006 | 10:35 AM
Slowhawk's Avatar
LS1Tech Sponsor
I would do a small Cam and leave the compression where it is.A populer Cam we do is a XE 220/224 on115 duration.Extremely streetable which makes real good midrange.Probly gain 40-50hp peak but 35-45 across the midrange.
Old Dec 21, 2006 | 11:10 AM
LSs1Power's Avatar
Its 224/230 .587/.593 on a 114 LSA
Old Dec 21, 2006 | 11:28 AM
pakisho's Avatar
224/228 .581/.588 on a 114.
Old Dec 21, 2006 | 12:14 PM
Lawnboy's Avatar
Restricted User
How do you think the Thunder racing cam will idle and what do you think of the High 117 LSA and that it only has one degree burned in 117 LSA (+1 116CL) ? How do you think it will afect the Power range? It is suspose to be a off idle to 6,800 RMP camshaft.
I like the extra exhaust duration this thunder cam has, but still not sure on the 117LSA and 116 CL.
Also being my car is a 100% street maching what ramp rate ( Compcams Lobes) should i go with? XE, XER, the new XFI,, what are the differances between them?
some say to put the cam on a 115-117 LSA but have degrees burned in so i end up with a 112-114 CL , to have good bottom end TQ and so that the cam makes usable street power in the lower RPM range ( to bring down the power band).. Where the thunder cam is on a higher CL, I wonder how this will affect my power range and will my car be dead under 4,000 RPM and not start pulling to later on, I dont think this would be good on the street, but maybe with the Procharger blower it doesnt make a big diferance.
I was thinking of doing my own special grind and take a little from everywhere and everthing i know and heard>
A LS1 blower camshaft something like this 216-230 with 580 to 600 lift on a 116 LSA + 4 degrees (112cl)
still not sure on what Lobes.
Jay from absolute speed that ported my stage 1X 241 heads flowing 300cfm at .550-.600 lift , said to have a compcam built on a 214-224 585/565 lift on a 116 + 4 degrees with XE intake lobes and the more agressive XER exhaust lobes.
I know he knows his **** so thats why i trust what he recomended, and he recomended A 115-116 LSA for a stock like idle and the +3 or + 4 degrees (112-114CL) to keep a nice streetable power curve .
I know he said at the time that this 214-224 Blower cam would have good street manners , idel like stock and make good power, and the 112CL would bring down the power range , where the LS1 is kinda dead, but i dont remember what he said about upper RPM < I want to be able to take her up to 6,500 RPM without the cam running out of steam and falling on its face,
But i think because of the forced induction , from the blower that this would not happen.
let me know what you guys think
Old Dec 21, 2006 | 01:10 PM
WHPLASH's Avatar
Thats almost like my cam.
Old Dec 21, 2006 | 01:23 PM
LS1Tech Co-Founder
Good luck, maybe whplash has a sound file for you. I don't like the idea of 116-121 lsa's.
Old Dec 21, 2006 | 01:55 PM
stevieturbo's Avatar
Why ??
I briefly used the GT2-3 from Lingenfelter with my 346....should have stuck with it longer though.
Id idled totally smooth, and did feel good on the road. I only stuck with it for 3-4 days before going bigger. With hindsight, that was stupid, but sometimes these things just happen.
Quite a few have had good results with that cam.
Old Dec 21, 2006 | 06:28 PM
Got Me SOM's Avatar
I wish I would have went with this cam
Old Dec 21, 2006 | 06:34 PM
Got Me SOM's Avatar
that cam should make power to 6500 easy.
my cam pulls hard from mid to up top. graph never goes down. we let off at 6700
you dont need a crazy cam with forced induction, only need something to help compliment the setup.
Old Dec 21, 2006 | 08:08 PM
Lawnboy's Avatar
Restricted User
Some ?
Hi gotmesom what cam are you using , what are the specs?
HI stevieturbo, so what cam did you end up with and how do you like it , why shouldnt you have changed from the G2-3 cam?
Hi Prostock John again, why dont you like the idea of 116 and up LSA's ?
Please let me know
And thank you for helping me out
Old Dec 21, 2006 | 08:22 PM
Got Me SOM's Avatar
224/230 on a 115
.581/.588
has a nice chop, you know you got a cam in there. pulls and pulls and pulls. idles great, takes some tuning to get it right. but its perfect now.
if its a street car you want something with a lot of midrange.
Old Dec 21, 2006 | 08:51 PM
mikep2002's Avatar
Originally Posted by Got Me SOM
224/230 on a 115
.581/.588
That is about the same cam I run on 7lbs .567/.588 114+2. I think I am gonna step up just a bit to the F7 if I find one reasonably priced.
Old Dec 21, 2006 | 08:55 PM
Got Me SOM's Avatar
f7 is the same i have i believe. you probably wont see that big of a difference. the higher lift should help.
i wonder if i went to .600 lift if that would have made a big difference.
