S91 vs. GT55-91
Old Jan 1, 2007 | 12:47 PM
DrTurbo's Avatar
LS1TECH Sponsor
Originally Posted by 509TURBOFIREHAWK
Dr T, what backing plate are you guys using on the S95, is it the steel on like the Garrett's or can you put an aluminum on there to save a little weight?
The backing plates are steel since the center section is one piece. Unit weighs about the same as a standard thumper.
Also an S95 will make 200-300hp more then a GT55.
Old Jan 2, 2007 | 11:28 AM
509TURBOFIREHAWK's Avatar
Dr T, What is the weight of the S95's?
Old Jan 2, 2007 | 12:05 PM
DrTurbo's Avatar
LS1TECH Sponsor
Same basic weight of a thumper. Most are about 70lbs or so.
Old Jan 2, 2007 | 02:15 PM
V6 Bird's Avatar
so ideally a 370-388 would put a 370 ci in its efficiency range spinning it to 7500 shift points?
Old Jan 2, 2007 | 06:52 PM
DrTurbo's Avatar
LS1TECH Sponsor
With a turbo that big, yes you will need some RPM's to get things efficient.
Old Jan 3, 2007 | 09:14 AM
V6 Bird's Avatar
I dont want a 400 CI motor. So with out too much RPM what CI would be ideal 7500 - 8000 rpm is all i want to spin and still be able to drive it on the street every once and awhile.
Old Jan 3, 2007 | 09:58 AM
FormulaFire's Avatar
You could do it with a well built 391.. I'd say.. atleast I'm thinking about trying it with one
Old Jan 3, 2007 | 11:06 AM
DrTurbo's Avatar
LS1TECH Sponsor
A very good high flowing 370-380ci engine would work well. The heads will be the key. With an efficient enough head you will be able to move more air at a lower RPM.
Old Jan 3, 2007 | 11:25 AM
V6 Bird's Avatar
It will flow very well in the head dept.
So im still likeing the 370ci basement.
Old Jan 3, 2007 | 11:33 AM
DrTurbo's Avatar
LS1TECH Sponsor
Sounds like a good setup then
Old Jan 3, 2007 | 11:56 AM
PHIL H's Avatar
Have there been many failures of GT55-91's in twin applications? I know i havent heard of Lynch having any problems with his so far..
Old Jan 3, 2007 | 01:04 PM
  #32
DrTurbo's Avatar
LS1TECH Sponsor
The GT55's are not going to hold up under extended abuse. The bearing structure on them is a little small for the size. That is why you see some of the DR cars not running them anymore. Pedaling it will kill the thrust.
Old Jan 3, 2007 | 01:56 PM
  #33
Dr T, is there anything to the new bearing systems that Innovative has, there the Super Duplex and F2, Just curious as to what they are and how they compair to whats allready out there? I havent seen any info about them. Im not a big fan of the Innovative stuff, but it is interesting.
Old Jan 3, 2007 | 02:01 PM
  #34
PHIL H's Avatar
I also see Lynch not running a BOV. Is that hard on them also? What turbo do you offer with similar power levels and spooling capibillity?
Old Jan 3, 2007 | 02:20 PM
  #35
DrTurbo's Avatar
LS1TECH Sponsor
As far as I know, the bearings are a little more durable, but that is pretty much it. They still use standard UTV garrett wheels.
Jose knows more about this then I do. Jose and Jason are working with some of the bearing companies to engineer some for the S-series.
Old Jan 3, 2007 | 02:36 PM
  #36
DrTurbo's Avatar
LS1TECH Sponsor
He's running alky now
Running without BOV's is not a good idea, but since they are automatic cars they will live longer. Most guys run BOV's though, but they are hidden or on the inside of the car on the intercooler itself, which I think is where Lynch has his mounted.
Old Jan 3, 2007 | 05:08 PM
  #37
PHIL H's Avatar
I keep hearing that he is switching to alky, but others close to him deny it..Must be top secret!!
Old Jan 3, 2007 | 06:15 PM
  #38
I think in that picture, those are GT47's. Dont the GT47's have six blades, and the GT55's have 7 blades on the compressor wheel?
I wouldnt want to run any of the Innovative stuff, I was just curious about those bearing systems, as if you read on there site, you would think it the best thing since sliced bread.
I tell ya what as soon as I get these two Y2K's ive got for sale gone, Im going to ride over to you guys and pick me up a pair of those S95's as soon as I can.
Old Jan 3, 2007 | 07:27 PM
  #39
NA$TY-TA's Avatar
Dr Turbo..... When ya get a chance ask JZ what the price will be to step up to the 91mm unit in my S88 i have now.......
Always gotta have a back-up.. LOL
Old Jan 3, 2007 | 07:47 PM
  #40
DrTurbo's Avatar
LS1TECH Sponsor
GT47's do have 6 blade comp wheels and GT55's have 7 blade comp wheels. S95's have the new 8 blade ETT design. Below is a picture of all 3 compressor wheels. You'll see why the S95 flows so much air.
Left to right..... GT55, GT47, S95
Attached Thumbnails S91 vs. GT55-91-gt55wheel.jpg   S91 vs. GT55-91-gt47wheel.jpg   S91 vs. GT55-91-s95.jpg
