ATI 6rib & 8rib differences?
Old Dec 28, 2006 | 06:58 PM
H&H Performance Depot's Avatar
Default ATI 6rib & 8rib differences?
What is the difference between the ATI 6rib and 8rib other than the pulleys and belt?
Thanks, Jeffrey H.
Old Dec 28, 2006 | 07:08 PM
The Red WS.6's Avatar
Good q. Got the 8 rib off the bat. Didn't want belt slip so I upgraded. Im pushing 8psi of boost. Don't know how bad the 6 is or could be.
Old Dec 28, 2006 | 09:00 PM
Funkybird's Avatar
These pulleys are off an LT1 Procharger kit, will they work on an LS1 setup?
[IMG][/IMG]
Old Dec 29, 2006 | 04:32 AM
EPP's Avatar
EPP
Smile
[IMG][/IMG]
No they won't. Bob
Old Dec 29, 2006 | 04:35 AM
EPP's Avatar
EPP
Smile
Thanks, Jeffrey H.
The 6 rib kit comes standard with the thinner 3.5" twin intercoolers, where the 8 rib kit pn# 1GJ204-SCI kit comes with the thicker 4.5" twin intercoolers.
The 8 rib kit also requires the use of a different harmonic balancer made by ATI Performance Products. The blower crank pulley then gets bolted to the new balancer. Bob
Old Dec 29, 2006 | 11:30 AM
Does going to an 8rip solve the belt slip issue (less than 10lbs) or is it better to go better with something else?
Old Dec 29, 2006 | 09:36 PM
EPP's Avatar
EPP
Smile
It certainly does. We had good results with the 8 rib belt at 16 psi. http://www.exoticperformanceplus.com...Car.php?car=42 Bob
Old Dec 29, 2006 | 10:14 PM
jegan1989's Avatar
is there a belt bigger than an 8 rib if you are going for more power with a d1 or f1
Old Dec 30, 2006 | 07:40 AM
EPP's Avatar
EPP
Question
Not on our LS1 engines. There just is not enough room to put a 12 rib on there. Bob
