Next step above 76GTS
Old Dec 30, 2006 | 01:22 PM
Turbo LS1 SS's Avatar
how much more does that 80mm compressor upgrade for the 76gts give you?
Old Dec 30, 2006 | 02:07 PM
engineermike's Avatar
According to the website, it's worth an extra 100 hp capability. However, it really depends on where you are on the compressor map as to how much it actually helps you.
Old Jan 2, 2007 | 11:24 AM
TurboGoat's Avatar
Originally Posted by DrTurbo
The PT88 is a possible next step, but most folks don't want the extra lag that comes with a TV unit.
Does the pt88 fit on a t4 flange and whats the a/r?
anyone else have any thoughts on it
Old Jan 2, 2007 | 11:26 AM
DrTurbo's Avatar
LS1TECH Sponsor
T4 it is, but its a 4" downpipe and uses a .96A/R. Also the exhaust housing is quite a bit larger and the length is about 2" longer.
Old Jan 2, 2007 | 11:39 AM
TurboGoat's Avatar
so I guess that one is out of the question since I only have the 3" DP to work with right now
Old Jan 2, 2007 | 03:26 PM
MIGHTYMOUSE's Avatar
i like my pt88, and i was only 364ci and a manual trans at that... lag not a problem for me.
the mouth of the exhaust on this turbo is 4 as i have pictured here, but the turbine wheel size is less.. and i have been running with good results on a 3.5" dp.
http://www.richmondperformancemuscle...cture3921.aspx
Old Jan 2, 2007 | 06:29 PM
MiaSSmaro98's Avatar
subscribing
