max boost on 408
Old Dec 31, 2006 | 10:35 AM
azooooz's Avatar
Default max boost on 408
I have 408 iron block with 8.5 CR and comtec head gasket ,ARP studs ,stage 3 patriot heads ,dry sump ,custom turbo camshaft .
I will use c16 racing fuel.
what is max boost I can go with ?
this engine is on a race car only.
BTW I am using thumber 96 turbo
Old Dec 31, 2006 | 10:43 AM
Navy David SS's Avatar
A LOT Most will depend on the size of the turbo and just how good the tuner is. IMO other factors: intercooler set-up; intake set-up; etc. We've done 18-19lbs and pulled close to 1K rwhp - could never get the car to stay on the dyno without having the tires go up in smoke. On the twin T-67's, I have been told I could easily do 22-24lbs with my set-up (which is similar to your's minus the dry sump).
David
Old Dec 31, 2006 | 10:45 AM
y2khawk's Avatar
30+, and no I'm not kidding
You may not make it that high with those gaskets and heads though. I had good luck with an MLS gaskets, but we've also had good luck with copper/o-rings.
Old Dec 31, 2006 | 10:52 AM
azooooz's Avatar
thanks for the fast reply
I just edited my thread with the turbo size .
the intake is victor jr
air to air I/C with co2 spray and a lot of NOS to kill the lag
Old Dec 31, 2006 | 11:02 AM
bad95killer's Avatar
i think 22-24psi can easily get ya over 1K rwhp buddy but as harlan mentioned ya need better head gaskets !!
peace
Old Dec 31, 2006 | 11:09 AM
y2khawk's Avatar
Spraying that setup is asking for issues IMO. With the right converter/tune you won't need to worry about spooling that turbo.
Old Dec 31, 2006 | 01:48 PM
eviltwins's Avatar
Agreed. Spraying is for people running GT55-91's on 3.4L Supras with a 6-speed. With a 408 and a 96mm turbo you can get that going on the converter no problems.
Old Dec 31, 2006 | 02:01 PM
LSs1Power's Avatar
I think the limiting factor would be the injectors on a stock PCM unless you are running a standalone.
Old Dec 31, 2006 | 02:12 PM
Speed's Avatar
Boost is only limited by the size of your stones. Do you clank when you walk?
Old Dec 31, 2006 | 04:02 PM
1dirtyZ's Avatar
if its going in the stang then the more boost the merrier
harlan, what studs are you using? and is that enough to keep the heads from lifting?
Old Dec 31, 2006 | 04:08 PM
Jammer's Avatar
The weakest point is the heads...standard deck height...4 bolts per cyl....Id say a sustained 20-24 lbs shouldnt be an issue...but you will start to push water.
Old Dec 31, 2006 | 08:43 PM
EATON22's Avatar
I have seen the Buick Grand Nationals run 21-24 PSI all the time. Heads were o-ringed; studs; but 21-24 should not be an issue if the entire system is build for it.
