Help with diagnosis?
Old Jan 7, 2007 | 12:56 PM
REDCYCLE13's Avatar
Default Help with diagnosis?
I ran my car at the track last night, and when I was done I noticed the car spit oil from the oil filler breather. I cleaned it up and took it easy going home. I never had any misfire codes or audible knock. I popped the hood again when I got home, and the breather was smoking a little. So I pulled all the passenger side plugs which looked good. No oil or anything on them. Just a light brown tint on all the electrodes. So I crank the car hoping it wouldn't smoke, but it did so I shut it off. I then went to the passenger side of the car, and could hear what sounded like a cylinder slightly hissing. It did this for a few seconds then stopped. I'm guessing a ring or something broke, but hoping it's not that serious. What do you guys think? New motor in my future?
Old Jan 7, 2007 | 02:47 PM
MECHAM's Avatar
your pcv might not be enough.
are the ports on the valve covers capped?
Old Jan 7, 2007 | 04:37 PM
REDCYCLE13's Avatar
No the ports are not capped. The PCV system is stock with the exception of a catch can, and oil filler breather. I did find a hole in the PCV line where I had put the catch can. The hole was pretty big. Could this have anything to do with the problem. The car seems to run fine.
Old Jan 7, 2007 | 05:41 PM
ozws6's Avatar
I would do a leak down test to check if you have a weak cylinder.
Old Jan 7, 2007 | 06:10 PM
otherwhitemeat's Avatar
my car has blow by too. it is normal... my car makes 1200hp and the motor will probably need to be gone through every 2 summer. power wears things out.
