Is this a good turbo?
Old Jan 7, 2007 | 06:07 PM
datsbad's Avatar
Default Is this a good turbo?
T76 Q-trim with a .96a/r
WOULD this get me in the 9's
Old Jan 7, 2007 | 06:54 PM
Project GatTagO's Avatar
Jason...what kind of car? What is the projected weight of the car?
Andrew
Old Jan 7, 2007 | 07:01 PM
datsbad's Avatar
Andrew
Andreww its a 98 F body . I found this turbo for a good deal but however I think it maybe to small. What are your thoughts?
Old Jan 7, 2007 | 07:08 PM
Jason,
If you assume a race weight of 3500 pounds, your going to need about 650hp at the crank to break into the 9s, assuming a very well tuned chassis. I think a t76 is capable of that given a properly designed system. Just my 2 cents. I am sore guys will more experience can be even more helpful.
Andrew
Old Jan 7, 2007 | 07:14 PM
Superman09's Avatar
LS1Tech Sponsor
im going to say its too small for those cubes. Kyle had trouble with his 76 on a 370. I say check out an 88mm for that 402.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Jan 7, 2007 | 07:15 PM
datsbad's Avatar
this is not for a 402, stock cube LS1
Old Jan 7, 2007 | 07:17 PM
datsbad's Avatar
Jason,
Andrew
I had planned of doing a 76 GTS but I foud this q trim and was wondering. I am not up on all the turbo sizes and letters that go with them
Old Jan 7, 2007 | 07:34 PM
Superman09's Avatar
LS1Tech Sponsor
well the 76 should fit the 346 well then, i was going off your sig, sorry. Best of luck!
__________________
Old Jan 7, 2007 | 08:51 PM
datsbad's Avatar
I was hoping it would , the Q trim threw me off some.
Old Jan 7, 2007 | 09:30 PM
engineermike's Avatar
The T76Q will probably barely squeek into the 9's if everything else works well. The difference between the Q and the S is that the S will barely squeek into the 8's.
Mike
Old Jan 7, 2007 | 09:38 PM
DrTurbo's Avatar
LS1TECH Sponsor
The old Q-trims aren't very efficient on engines like the LS1's, but you may could get there.
Old Jan 7, 2007 | 09:48 PM
datsbad's Avatar
Thanks I am going to pass on it then .
you have 76 GTS or MPS in stock ? Pm me some pricing.
Old Jan 8, 2007 | 01:15 PM
DrTurbo's Avatar
LS1TECH Sponsor
PM sent.....
Old Jan 8, 2007 | 01:26 PM
eviltwins's Avatar
I'd bet with an auto and a stock cube LS1 you could go 9.40's at 3500 pounds with a 76 Q-trim.
