D1SC... Opinions?
Old Jan 9, 2007 | 07:50 AM
nikon1999's Avatar
Default D1SC... Opinions?
Thinking about picking up a d1sc kit and adding a fmic to it.. Probably running 6-8lbs on top of my h/c setup? Edelbrock 205cc heads which have a real thick deck and everyone says are great for FI... have a even split cam which should be good (just big)
I was thinking about a turbo setup, but will end up costing me alot more $$ in the long run, and i dont think i need that much power... Supercharger seems like it would be a little easier on the car? Reading posts it seems like with the right setup they'll make gobs of power anyways... i'm thinking with my h/c setup and the little boost i should still be in the 550-600 range with a very mild boost setup? Which i'd be fine with
Old Jan 9, 2007 | 08:01 AM
Cyborg's Avatar
Absolutely time tested and time proven. They are awesome. You want a 114-117 LSA though not sure what your cam has.
Old Jan 9, 2007 | 08:19 AM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Lets play scrabble: B@PEBOP.
It spells Bob @ EPP. He has you covered.
Old Jan 9, 2007 | 09:32 AM
nikon1999's Avatar
why that lsa? mine is 112...
Old Jan 9, 2007 | 09:59 AM
cablebandit's Avatar
dont get one...KP ran 5s in the 1/8 and low 9s in the 1/4 with his on a 347. He ran lo 6s in the 1/8 with the d1sc and a z06 cam...killer combo...i think you will be happy
Old Jan 9, 2007 | 10:16 AM
eb02z06's Avatar
D1SC rocks-600rwhp is a walk in the park-call BoB@EPP it doesn't get any easier than that.
Old Jan 9, 2007 | 10:25 AM
Cyborg's Avatar
You don't want a big cam w/ lots of overlap on a blower car, it will not make power until very high RPM and driveability will be poor.
Old Jan 9, 2007 | 10:43 AM
nikon1999's Avatar
despite the lsa the cam has really no over lap, its a pretty even split from the way i understand it..
I'm really leaning towards it...
Old Jan 9, 2007 | 05:19 PM
Hype's Avatar
As everyone else said, you can't go wrong with a d1sc kit. I wouldn't worry too much about your cam, I've seen so much theory with cam choices and I've seen a lot of cams not in that theory working quite well as well. Try your cam now and swap it later if you don't like the results.
As a side note, I'm not sure you will need the fmic, the twin intercoolers might be enough, I'd do a search to be sure... it might save you some cash.
Old Jan 10, 2007 | 04:13 AM
EPP's Avatar
EPP
Thanks guy's, check out the cars in the project car section of my website that are running ATI ProChargers, a lot of pictures in there. This list may possibly help you out also. http://www.exoticperformanceplus.com....html?item=540
Bob
