Colbolt 2-bar map sensor install?
Old Apr 24, 2007 | 12:02 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Originally Posted by onfire
Same kPa spec but I don't remember if it is the same part number. A Delphi engineer sent it to me in an email with a cross reference to the Cobalt sensor.....which is a BAP sensor not a MAP sensor BTW.....that's what causes all of the confusion since the Cobalt uses a 2.5 bar Map sensor and a 2.0 bar bap sensor. Can't use a Cobalt 2.5 map sensor since it has other integrated funtions.
Oh ok gotcha. Thanks for the clarification
Old Apr 24, 2007 | 08:03 PM
nvmy2000ss's Avatar
Default Different approach
heres another way. I like it cause it is easy to get to.
Then you run a vacume line to the sensor from the barb fitting
