Dyno numbers
Old Jan 22, 2007 | 10:29 PM
STKN1STGEAR's Avatar
Default Dyno numbers
Hi,
I just got back from the dyno.
I built an LS2 forged lower end w/ probe pistons and connecting rods, stock LS1 crank, 98 heads CNC ported w/ 2.02/ 1.57 valves, stock LS1 intake, Vortech super charger @10 PSI, siemans 60# injectors and meth injection. I ran into a fuel problem, @ 8 PSI of boost and 5300 RPM, the fuel PSI starts to drop from 65 PSI to 40 PSI. I do have a booster pump and did try adding a voltage booter on top of it, this did help but wasn't enough. these are the numbers so far.
I'm hoping to get 30 - 40 more WRHP with a fuel pump upgrade
File Type: pdf
Old Jan 22, 2007 | 10:35 PM
Inspector12's Avatar
TT-TECH Veteran
I got to 575 with the stock vortech booster pump before it ran out, then I went a Racetronix intank with a MSD BAP went over 600 without a problem FYI. Good numbers.
Jeff
Old Jan 22, 2007 | 10:40 PM
Jeff
Excellant !!!!!!!!
I ordered the same setup today.
Hope to have it by the weekend.
then back to the dyno
AL
Old Jan 23, 2007 | 12:22 AM
DeltaT's Avatar
Nice numbers, especially for 10#. What's your displacement?
Jim
Old Jan 23, 2007 | 10:42 AM
Jim
Jim,
Thankx.
It is a stock bore LS2
Thankx
Al
Old Jan 25, 2007 | 09:17 PM
This car is really fast now.
I can't even use 1st gear, or step on the gas in 2nd, the tires just spin.
I may have to change the gears back to stock.
Al
Old Jan 28, 2007 | 10:32 PM
Jeff
Jeff
What are your dyno numbers like?
Al
Old Jan 28, 2007 | 10:38 PM
Mike00ss's Avatar
Real nice numbers!
Old Jan 29, 2007 | 11:31 PM
Originally Posted by Mike00ss
Real nice numbers!
Thanks
AL
