Prochargers with nitrous
Old Jan 28, 2007 | 12:28 PM
CALL911's Avatar
Originally Posted by JASON11WS6
Thanks for the imformation, I was not aware that methanol was sprayed constantly. How many MPG would you usually get with an average set up. Would you have to fill it a lot, or could you fill it every time you get gas? Sorry, I never bothered to learn to much about it before.
It's not necisarily sprayed constantly. To have a good tune on it, it usually sprays according to your boost level. More boost=more spray. No boost=no spray. I drive my car all the time without getting into boost. Even if you just get into traffic and only ring the boost meter up to a few pounds, you won't use much at all. Honestly, if you are going to the track, and are doing WOT runs, a gallon of methanol will still probably last you somewhere around a dozen runs before you need to worry about filling the tank. Most setups giving you a warning such as using your cars low washer fluid light letting you know you are running low on the methanol.
Old Jan 28, 2007 | 01:10 PM
DJ's Z's Avatar
Originally Posted by BJC51984
Has anyone tried running a 50 to 100 wet shot of nitrous at WOT with a Procharger setup??? If so how did it work out??? Anything to watch out for or tips because I think I am gonna try running a 75 shot or so with the 8 lbs of boost??? Thanks in advance for any insight.
Works great!! Just watch out for 100mph lane swaping and sawing the wheel a few times to correct the non-compliant 315 BFG DR's...
Just "tune" it safely...Timing, A/F and run race fuel you should be just fine...
As you can see plumbed on each side of intake elbow...(well only 1 side is showing)
Old Jan 28, 2007 | 01:36 PM
99Z28LS1's Avatar
Plumbed on each side of intake elbow...
as if your car couldnt get any sicker, you do this...... ha ha
i love the car and cant wait to hear about you waxing some big turbo supras on the highway or 200 shot vipers.... ha ha
Old Jan 28, 2007 | 02:54 PM
CALL911's Avatar
DJ's99SS; Thats one stout lookin car you got there! Got any vids of it?
Also, who made your shiny black inlet tube to your elbow? It looks sweet!
Old Jan 28, 2007 | 03:13 PM
DJ's Z's Avatar
Thanks for the props...here's just a couple links to some vids...final dyno tuning was done at Conely's Performance here in Houston but clutch/tires were spinning so no best final HP/TQ numbers. Was close to 800RWHP on a Mustang dyno with clutch issues. No nitrous was used on these pulls...Other dyno vid was done in Dallas at the July Jam Dyno day. Mike (Icon AutoSports) seen trying to cool down the FMIC. Was 115 degrees in the shop that day. Car made 880RWHP blowing through a Spec 5 Clutch...
http://media.putfile.com/Dyno-Pulls
http://www.youtube.com/watch?v=klqyBHLSyHw
http://videos.streetfire.net/video/7...bdfb121c15.htm
The inlet tube is from the kit Bob at EPP puts together for the FMIC and plumbing. I had all the plumbing powder coated...
Old Jan 28, 2007 | 04:04 PM
CALL911's Avatar
Looks good man. I also have an FMIC from Bob at EPP, however my tube to my intake is from ATI. The car looks sickly powerful. Get a street twin and some slicks on that mug!
Old Jan 28, 2007 | 04:22 PM
DJ's Z's Avatar
I've had that taken care of...
Old Jan 28, 2007 | 04:42 PM
CALL911's Avatar
You and I are two of the same mind my friend!
Keep us posted after you get the clutch in and the slicks mounted.
Old Jan 28, 2007 | 06:15 PM
99.9percenter's Avatar
[QUOTE=DJ's99SS]I've had that taken care of...
What clutch is that?!!
Old Jan 28, 2007 | 06:51 PM
Frost's Avatar
... Most setups giving you a warning such as using your cars low washer fluid light letting you know you are running low on the methanol.
An F-body does not have such a light... But the Alkycontrol kit comes with a modded tank (if you order it) that has a level sensor among other advantages...
Old Jan 28, 2007 | 06:58 PM
JMBLOWNWS6's Avatar
I would spray a max of 100 shot. Your cylinder pressure is high enuff with the boost! Put it this way. Sprayed a 50 shot and ended up almost making 92 rwhp.
Old Jan 28, 2007 | 07:11 PM
  #32
1MEANGTO's Avatar
I currently have a wet kit on my stock motor right now. I am in the midst of putting together a forged bottem end for the D1sc kit I bought. I was planning on just running the blower and leave the shot on it for a little extra fun every now and again. I figured it would be next to impossible for my hands to remove that kit from the car. To much fun!! Anyway I was also considering some meth too, maybe not with the spray but for the track. I figure nitrous would hit harder but I am sure meth is a lot cheaper to run at the track. If anyone runs both regular please let me know, that's awesome stuff. Maybe some E85 if I can learn more about that stuff.
My new combo is e85 fed. Way low temps with monsterous boost
Old Jan 28, 2007 | 07:36 PM
  #33
CALL911's Avatar
Actually, yes my 95 Z28 does have such a light. Almost all the meth injection kits come with a low level sensor in them. You can rig it up to anything you want. LED light for example.
Old Jan 29, 2007 | 11:17 AM
  #34
Got Me SOM's Avatar
Did you go wet or dry? Do you have a pic where you mounted the nozzle?
I want to do this really soon.
Old Jan 29, 2007 | 12:07 PM
  #35
99Z28LS1's Avatar
and cheap gas
Old Jan 29, 2007 | 12:10 PM
  #36
Frost's Avatar
I should have been more clear The LS1 cars don't have them from the factory.
Old Jan 29, 2007 | 12:11 PM
  #37
99Z28LS1's Avatar
[QUOTE=99.9percenter]
i second that notion
Old Jan 29, 2007 | 01:35 PM
  #38
DJ's Z's Avatar
[QUOTE=99Z28LS1]
It's the Textralia Exo-Skel Triple Disc...
Old Mar 31, 2007 | 12:06 AM
  #39
Rickys S/C Z28's Avatar
wow that nuts mang!!
Old Apr 27, 2007 | 10:56 PM
  #40
BIG BAD BLACKSS's Avatar
Anyone else doing anything new or have anything else to add, still trying to learn about nitrous and blowers or boost in general!
