How to launch a turbo car?
Old Jan 29, 2007 | 04:08 PM
cablebandit's Avatar
Spazman thats how i do it. I think there is a better method using a 3 step Also, your footbrake prolly wont hold much over 3000rpms. harlan is coming out with a 3 step soon...that will be the bomb-diggity!!!
here is a little vid i made of my tbrake and 2 step in the driveway. ignore the low oil light In the last segment, you can see the boost coming up but it skyrockets once it hits the 2 step rpm
http://cablebandit.net/videos/t-brake.wmv
Old Jan 29, 2007 | 04:16 PM
ABeasst's Avatar
whats a 3-step?
Old Jan 29, 2007 | 04:36 PM
read this thread and a good vid showing a "3 step"...now harlan where is that damn thing for sale?
Old Jan 29, 2007 | 07:49 PM
ABeasst's Avatar
I did read it and didnt see it mentioned until now. I have a 2-step and hadnt heard of a 3-step. Is that a 2-step plus a transbrake??
Old Jan 29, 2007 | 08:03 PM
Turbo Tech's Avatar
A three step is like the two step but with another module. When we use a three step we use one triggered by the brake lite switch, another by the launch or trans brake button and the last is a rev control. Three step is mostly used on pro tree racing.
Old Jan 29, 2007 | 08:54 PM
duh...forgot to post the link
https://ls1tech.com/forums/drag-racing-tech/405027-2-step-users-potential-users-need-input.html
Old Jan 29, 2007 | 09:31 PM
NA$TY-TA's Avatar
sweet vid
Kyle
Old Jan 29, 2007 | 10:44 PM
RICE ETR's Avatar
Turbo Addict
I had a Harlan 2-step.....it worked great.... great enough to break the back off my tranny...so i have since sold that and been launching via my right foot. So far i have cut a high 1.5ish on BFG DR's feathering the throttle as i let out on the clutch.
Old Jan 29, 2007 | 11:00 PM
RICE ETR's Avatar
Turbo Addict
PS....stock compression and T76 righta herea...
Old Jan 29, 2007 | 11:09 PM
SScam68's Avatar
Originally Posted by cablebandit
That was a over a year ago
Still holding your breath? I am
Old Jan 30, 2007 | 08:51 AM
NA$TY-TA's Avatar
It will be out..... he has alot on his plate and making a 2-3 step is his 1st job......
Kyle
Old Jan 30, 2007 | 08:55 AM
  #32
spare tire's Avatar
I like the video, very cool
Old Jan 30, 2007 | 09:24 AM
  #33
tirefryin_s10's Avatar
how about an auto car with no t brake .... 2 step and foot brake to as high as itll hold?? i have a tc1 3800 converter and a full manual th400 ...... curious as to the best way to build boost outta the whole
Old Jan 30, 2007 | 11:48 AM
  #34
i tried that...my ls1 brakes wouldnt hold over 2800-2900 rpms....1.7x 60'....with footbrake and 2 step, 1.5x 60'...i have a tight converter so it needs the boost off the line
Old Jan 30, 2007 | 11:52 AM
  #35
so your recomending holding the foot brake engaging the 2 step and flat footing it to as much as it will hold to build boost then let it rip?
Old Jan 30, 2007 | 12:47 PM
  #36
exactly.
Old Jan 30, 2007 | 01:04 PM
  #37
do you feel the 2 step a neccesatiy(sp) in buildign a decent amount of boost out of the hole?
Old Jan 30, 2007 | 01:15 PM
  #38
on the footbrake, my car would not build ANY boost at 2800rpms...4-5psi with the 2 step
Old Jan 30, 2007 | 01:17 PM
  #39
why is that ? how is it that taggin it off a limiter builds boost? not doubting it just curious is all
Old Jan 30, 2007 | 01:34 PM
  #40
black98ws6ta's Avatar
Post #6 in this same thread. A stock limiter is fuel cut, we are talking about using a ignition cut 2 step.
