Supercharger and EGR
Old Jan 29, 2007 | 10:30 AM
tici's Avatar
Default Supercharger and EGR
How tight is the EGR valve?
Is it possible that under boost some air goes through the EGR system?
I'm not worried about the boost lost, but my wideband is installed in the passanges exhaust side (right befor ethe cat) and if the EGR has a leak my AFR measurement will be wrong
Any idea?
Thanks - Stefano
Old Jan 29, 2007 | 10:58 AM
98turbls1's Avatar
You could do a test to see if it's leaking or just block it off entirely...
Old Jan 29, 2007 | 11:42 AM
tici's Avatar
What is the disadvance to block it off? Fuel consumption while cruising?
While the EGR is open the timing is slightly advanced (see the attached pic).
I can't tune it out directly because I have LS1Edit, I have to reduce timing in that area in the main timing table.
Is that a good idea?
Do I really have to worry?
Old Jan 29, 2007 | 12:13 PM
kp's Avatar
kp
EGR should be closed at WOT, you will not make boost at part throttle where the EGR is pulling spark in that table.
I had the EGR on my old z28 with a blower and all the other emissions junk (pre LS1edit days) and never had any problems..
Old Jan 29, 2007 | 12:37 PM
tici's Avatar
100% no leaks?
If only a little air goes through the wideband will tell me crap
Old Jan 29, 2007 | 12:49 PM
kp's Avatar
kp
Originally Posted by tici
100% no leaks?
At WOT there is so much going through that wideband it probably wont matter.
If you are that paranoid just get rid of it, block it off and turn it off in LS1edit, or put the wideband in the other side.
Old Jan 29, 2007 | 03:24 PM
tici's Avatar
Yessss! I'm paranoid. Last night I wasn't able to sleep and all this sort of BS came in my mind
Something interesting in LS1Edit: if you turn off the EGR you'll have a code.
Like if the program won't know that if it's off the pintle won't be able to move
Do you think that turning it off will eliminate the additional timing advance?
Mhh... OK. I'll have to make a scan. And then log for AFR with the EGR active and then blocked off.
...always the complicated way to learn... try - try - try
Thanks anyway for your advices!
Old Jan 29, 2007 | 04:00 PM
kp's Avatar
kp
I'm pretty sure when you turn it off in LS1edit it no longer works, not sure about the extra advance but I assume that wont do anything with it off either. Just zero out that table, turn it off, unplug it, and turn off the MIL/tests for EGR.
Old Jan 29, 2007 | 04:40 PM
lt170chevelle's Avatar
i have an 94 lt1 and have the egr blocked off. am i losing any spark advance by any chance? if so is there anyway to fix this?
