twin turbo ls1 tuning
I'm thinking it would be $1500 for stock ecu, custom harness, and HPT... Or $2000 for BS3.
The tipping point is injector size and power goals to me. If you need to run low impedance injectors add $300 for a converter box and I think at that point the better choise is BS3.
stock ecu = free
one can clip wires and run extensions for a few bucks
HPT 3-bar is a few hundred (free if someone buys HPT and uses 2 of the provided credits)
injector driver is 250
This is way less than 1K
Just a personal opinion. For me, If you're going for that much power forget the driver and take the additional safety/benefits that BS3 has in one box.
I'm building my 1000+ setup around a stock computer
Cheapest $1150, priciest $1500
(ecu, harness, injector driver, hpt 2/3 bar).
"except for closed loop WB"........if you say that real fast, it's not much of a benefit....
Plus built in 2 step.
Plus it can drive low imp injectors without worry....a 'converter box' has somw worry built in.
Plus boost control.
Plus map control above 3 bar.
But I hear ya....I ran 710rwhp off a stock ecm last year. Plan on being +800rwhp this year. It's just better to have a BS3 if you're starting with a clean piece of paper and +1000rwhp for better power control on slick tracks, etc. Ask W2W.
David
Plus boost control.
over 3-bar, definately a plus, but not too many people have pushed a LSx platform over 30 psi
low-z injectors w/o worry...its the same electronics inside I bet as a converter box...not sure why running one would make me worry...
built in 2-step....single rev limit? Harlans new magic box supposed to multi-limiter w/ retard...once again is the BS3 comprable. Sometimes external items driven by a computer give more functionality (2-step and boost controller in this example)
