Setting up my PCV. Will this work?
Old Feb 7, 2007 | 02:26 AM
JD_Z28's Avatar
Default Setting up my PCV. Will this work?
I'm going to plug the TB and run a breather on the front passenger side valve cover port. Install a check valve and Home Depot catch can between the manifold and pcv system to help prevent boost from entering the crackcase.
Will this setup work and would it be a good idea to leave the stock check valve on the car or take it out.
Any help would be highly appreciated. After reading all the threads on PCV sytems I just got frustrated and gave up BTW, I'm going to be running 13 lbs of boost and where could I pick up one of these Check Valves?
Old Feb 7, 2007 | 10:18 AM
JD_Z28's Avatar
bump for a new day
Old Feb 7, 2007 | 11:40 AM
JAvenger007's Avatar
STS kit right? Last kit i helped put togethor we ran something along these lines:
but without the pump. Intake side of turbo works as vacuum.
Old Feb 7, 2007 | 11:46 AM
JD_Z28's Avatar
Yes its a STS kit.
Do you have any pics of your setup.
Old Feb 7, 2007 | 12:25 PM
JD_Z28's Avatar
Does anyone know if I could pick up a good PCV check valve at a autoparts store, if so does anyone have a part number?
Old Feb 7, 2007 | 01:05 PM
McMaster Carr makes a good one for pretty cheap. And no pics, my car is stock right now, sorry. I never did figure out my PCV setup, im still in the hunt like you.
anarchy99's Avatar
I got one from autozone... can't remember the part # though. It's a little silver one. They should have a section in the store with PCV valves of different sizes and shapes. I'd just bring a section of your vacuum line into the store and get one that fits on the line, thats how I did mine.
Old Feb 7, 2007 | 01:18 PM
98turbls1's Avatar
I wish that there was a sticky that gave a definitive answer in details with pics for each application...Such as front mount turbo, STS, Procharger or other centris, and other applications... I'm a little confused myself and I'm only dealing with a Procharger...
Oh BTW, you gonna have the 76 in for the big day this weekend??
Old Feb 7, 2007 | 01:43 PM
JD_Z28's Avatar
You know it
Old Feb 7, 2007 | 02:10 PM
WAHUSKER's Avatar
I did more or less the same thing only without the pump or breather. But then I have a s/c. And I stayed away from the breather because I don't like the notion of oil coming out right onto the headers....boosted exh temps are HIGH, fire bad!
Old Feb 16, 2007 | 01:57 AM
JD_Z28's Avatar
Default Sts Pcv
Sorry to bring this up again you guys. Can anyone please help me setup a simple and effective PCV setup. I've tried everything and no matter what I do I keep getting blowby out the breather. I'm trying to work with what I have and thats 2 small Home Depot CC's and 1 check valve. Can somebody please help me out My last setup I ran a check valve between the manifold and pcv along with a Home Depot cc, I plugged the TB and ran a breather right off the passenger side valve cover. Any help is highly appreciated.
Thanks,
John
Old Feb 16, 2007 | 02:11 AM
JD_Z28's Avatar
bump for a new day.
