Cheatr Cam w/D1SC?
Old Feb 7, 2007 | 01:09 PM
dixonk's Avatar
Default Cheatr Cam w/D1SC?
Anyone know if the Cheatr cam will work well with the D1SC running 7 psi? Or should I order a new cam?
Old Feb 7, 2007 | 04:36 PM
smoke20's Avatar
i cant answer how it would work with a supercharger, but i have it on my STS set up and it makes good power, some people tell me to change it that is not a good turbo cam, other say it works good. it is a low overlap cam so for turbo application that is good, im not as knowledgable about supercharger needs.
Old Feb 7, 2007 | 04:58 PM
scotts94_z28's Avatar
I would have to say it would be an awesome blower cam seeing that the specs for the cheatr 214/230 .601/.578 117 LSA are nearly identical as the specs on TR's blower cam 214/230 .601/.575 117 LSA but to be absolutly sure I would just go ahead and ask thunder racing themselves since they do make both cam's
Old Feb 8, 2007 | 08:07 PM
dixonk's Avatar
thanks
Old Feb 8, 2007 | 09:40 PM
E Wagz's Avatar
Have a blower cam from TR on the way. Will be running D1SC at 10psi with a ton of other mods. Shane in tech is the one you want to talk to. He is the one who recommended this cam and seems to know his ****. Not as extreme as you could be but should supply good power. I have a vert and this was part of the equation. Car should be 650-690 RWHP when tuned. Good luck.
Old Feb 9, 2007 | 08:03 AM
dixonk's Avatar
Im not looking at trying to run that much. Mid to High 500's is perfect since we won't have a track for another year or more here.
