compression
Old Feb 20, 2007 | 12:14 PM
moehorsepower's Avatar
[QUOTE=CALL911]Just my opinion here, but again, if you cut corners and don't get at LEAST the pistons, ARP head studs, and RODS , even with running low boost, and a good tune, there's no garuntee you'll make it to your 3rd oil change before you need to rebuild the motor.
Its all in the tune, I can tell you for a fact that 90% of all Forced inducted cars I have tuned are BONE STOCK (less larger injectors and aux pump)running 7-9 lbs of boost making app 500 RWHP, These cars have been running strong for over 5 years and these guys do not baby them... So I have to disagree with your statement..
Old Feb 20, 2007 | 02:14 PM
CALL911's Avatar
[QUOTE=moehorsepower]
Like I said, just my opinion from what I have seen (pretty much opposite of you). Most guys even with a conservative tune on the stock bottom end I usually talk with (quite a few, especially on cz28.com) make it maybe a max of 25,000 miles on their stock bottom ends if they are lucky before something goes. Just what I have personally seen, and people I have talked to. I'm sure there are others on the other side of the lucky fence who have made it longer. I have yet to talk to one though, and most don't even seem to make it more than 15,000 miles.
Old Feb 20, 2007 | 02:31 PM
jdime20's Avatar
i am getting low cr pistons, just thought the head would help as well. i think i'll get some rods too, even if the stockers would work i think i'll feel better knowing i have strong rods whenever i feel like pushing it hard
Old Feb 20, 2007 | 05:32 PM
Boosted LS1's Avatar
At the end of the day this thread is about investing money where it really counts imo. So you need a decent (forged) piston and ring package, maybe some nice shells and some good rod bolts. 317 heads help because of the ports as well as lowered cr but you can lower cr some more with the forged pistons. Aftermarket rods might be nice but they're probably heavier so for mild applications do you need them?
Boosted.
Old Feb 20, 2007 | 05:50 PM
ddnspider's Avatar
Originally Posted by SleeperZzZ28
there is so much wrong stuff in that paragraph I dont know where to begin.
smartest post in this thread.if you have a choice between having bigger cc heads or more dish in a piston you choose the heads.if youre only looking for 450-550rwhp id stick with the stock shortblock throw some 6.0 ltr heads make sure you can monitor knock a/f and tune tune tune and it should last quite awhile assuming your shortblock doesnt have any issues currently.
Old Feb 20, 2007 | 05:52 PM
ddnspider's Avatar
and ps a long time local buddy just made 700rwhp on a stock shortblock
Old Feb 20, 2007 | 07:06 PM
CALL911's Avatar
Just a matter of opinion I guess. I know plenty of guys that made only 500 RWHP or less on the stock block boosted, who fried a piston, a ring, or blew a gasket all under 5,000 miles.
Old Feb 20, 2007 | 07:09 PM
CALL911's Avatar
Boosted.
When it comes down to it, this is what really matters. Opinions aside, I think we can all agree that having a fully forged setup will be more reliable than a stock one.
You can either save money and go cheep, and hope to be one of those cars I haven't heard about, instead of the ones I have heard about. Or you can spend a little more for a more reliable setup.
Old Feb 20, 2007 | 07:25 PM
ddnspider's Avatar
if youre blowing a motor making less than 500rwhp,assuming the motor was in good shape b4 it was hit with a powe adder then your friends need a new tuner
Old Feb 20, 2007 | 07:32 PM
Tom@SpeedInc's Avatar
It just seems when you need forged pistons anyway that most people get low CR ones to change their CR as well.
FWIW IMO piston have alot to do with the build, and should be higher consideration then combustion chamber volume.
You can't take a dish piston motor and try to make it 11:1.
Old Feb 20, 2007 | 08:02 PM
ddnspider's Avatar
i completely agree with that,but the pistons and ringlands are thin enough for ls1's so when you add a 32cc dish or a 24cc dish they get even thinner.its different when your trying to drop the CR instead of raise it.
Old Feb 20, 2007 | 08:13 PM
  #32
CALL911's Avatar
Whatever dude. If it were just one or two guys doing the tuning themselves for the first time ever, then I might agree with you. But this is dozens of people who have thier car tuned by people who have been tuning F-bodies since they came out, and a couple of the tuners happen also to be some of the top tuners in volume for them. If that many people continue to do buisness with them, I doubt they are doing a lousy job.
Old Feb 20, 2007 | 08:17 PM
  #33
ddnspider's Avatar
well im not sure how they do tunes in NJ,im originally from NY,but in FL many MANY people are fine making over 400 and many over 500rwhp without blowing **** up.I had a H/C/I setup and did everything they tell you not to do with nitrous(ie N20 burnouts,spraying out the hole,spraying below 3k or whatever rpm) and never had a problem blowing anything up.I can start listing people boosted or spraying making high 4xx,5xx,and some 6xxrwhp.might wanna check out the boosted lists as a starter.
and edit....tuning a car for NA(which is more than likely the volumes youre talking about) is completely different than tuning a boosted car.many tuners are great tuning an NA setup and suck tuning an FI setup.
Old Feb 20, 2007 | 08:20 PM
  #34
CALL911's Avatar
If you want, I can start posting up the guys I know who have had issues as well.
BTW, the tuners aren't in NJ, and they do volumes in both power added, and N/A 4th gen F-bodies.
Old Feb 20, 2007 | 08:31 PM
  #35
ddnspider's Avatar
and what im saying to you is if you have a strong motor without the power adder,ie no issues already worn down motor,and your add the power adder and your making less than 550rwhp and people consistently have problems with motors blowing up its the tuner.i am giving you credit that some just let go and have problems but the majority will not have problems if it has a good safe tune making 550rwhp or less.my lists already been started like 4 years ago..read the boosted lists,you got some catching up to do on your list
Old Feb 20, 2007 | 08:33 PM
  #36
CALL911's Avatar
All I'm saying is that I've seen the opposite (several people with low mileage, or good condition motors, that go FI with even a mild or moderate amount of boost with a good tune on the stock motor that end up with issues).
We'll probably just have to agree to disagree on this one
Old Feb 20, 2007 | 08:35 PM
  #37
ddnspider's Avatar
thats cool,ive seen wierd crap happen to,but people are here to learn right?believe me ive made retarded posts and learned alot on here.what im saying is that maybe what you feel is a good tuning standard might not be as good as it could be if that many motors are having problems.
Old Feb 20, 2007 | 08:44 PM
  #38
CALL911's Avatar
Thats definatly something I can agree with. It's not a good idea at all to throw a blower on a high mileage motor, or one that is having issues. If you do, no matter what the tune, you are looking for trouble.
