Why do these numbers seem so low?
Not really any info on the heads. The car was at GMR up until around the middle of May then was down for awhile while the turbo kit was being built. Havent had it all long enough yet (or enough trouble with it yet) to get to really know anything about the setup
Ryan K.
Ryan K.
The heads are "fine" but without being ported, they are going to be a restriction.
Ryan K.
Ryan K
Well if the boost is steady then you can rule the wastegate and turbo out. If there was a problem with those, boost would drop on the top end. How about valavesprings...which ones are you using?
That being said, your numbers are promising except that you peaked really early. I'd look into that and look to understand if you ran out of turbo, injector, valvespring, or an into another issue.
Took Speed Inc. two separate dyno sessions to get my car to good numbers... springs and rockers needed to be changed.
