Turbo Motor For Lt1
Old Mar 3, 2007 | 07:03 PM
lt1383's Avatar
Default Turbo Motor For Lt1
What would be best TURBO MOTOR setup for a LT1 ?
What would be better to go with LS1,LS2 OR LQ9?
I have 94 Formula Firebird..
Old Mar 3, 2007 | 07:56 PM
otherwhitemeat's Avatar
lt1's have 5 head bolts so they can hold more power
Old Mar 3, 2007 | 08:11 PM
6techniques's Avatar
I say build up the LT1...Your car is already setup for it for one, and it will cost you less in the long run and also the 5 head bolts will allow you to hold a little more psi without trying to lift the heads.
Old Mar 4, 2007 | 06:04 PM
lt1383's Avatar
Im' about sell my setup which is 383. What should I do, I could buy or make new setup.This what I was thinking going with 355, AFR 210 ,TH-350 with trans brake 4000 stall.
Old Mar 4, 2007 | 08:05 PM
sounds fine to me...Do some reSEARCH on different combos so you can get an idea of how much power you want, and then from there decide on what setup you think will make you happy.
Old Mar 5, 2007 | 01:42 PM
lt1383's Avatar
I want to make about 900hp/1000hp .. Yeah I know this one guy got his mustang into 8's With custom Turbo kit , I spoke person made his kit iam looking 8 grand on whole kit .
Old Mar 5, 2007 | 02:03 PM
70Stang's Avatar
We are building one right now...Single Turbo, 1000+ is the goal.
Engine -
Callies Dragon Slayer Crank
Callies CompStar Rods
JE Pistons (8.5:1)
Callies Splayed Billet 4bolt Mains
ARP Everything
AFR Eliminator LT1 Heads
SBC Intake, EFI
Custom Aluminum Elbow & TB
C&R Radiator
Turbo Kit -
Precision GT42-76 Turbo
Tial 50mm BOV
Tial 44mm Wastegate
Custom Manifolds
Custom Intercooler (Huge)
Exhuast -
4" Downpipe, dumped out the front fender
4.5" Electric cutout
3" Exhuast ran out back
EFI
Autronic SM-4
95lb Racetronix injectors
Boost, Fuel Pressure, Wideband and Temp guages
MISC
Rebuilt T56 with all the goodies (probably explode)
10 Bolt (lol)
BMR K-Member, A Arms, Subframes, TQ Arm, LCAs, Panhard, etc...
Custom 6 point cage
ZR1s with big M/T DR's.
Old Mar 5, 2007 | 03:18 PM
i heard to stay away from the slayer crankshaft.......they have broken before
Old Mar 5, 2007 | 04:23 PM
70Stang's Avatar
Everything has broken before!
Old Mar 5, 2007 | 05:15 PM
raymond mckinney's Avatar
Talk to Speed Inc. if ur serious they'll give u some good advice.
Old Mar 5, 2007 | 07:14 PM
lt1383's Avatar
Been talking to one of guys getting there short block for now, when I do ,going to order sit AFR's 210 work myself from there.
Old Mar 6, 2007 | 08:05 AM
RealQuick's Avatar
Stick with the LTX platform... plenty of power to be made with it.
Old Mar 6, 2007 | 08:20 PM
lt1383's Avatar
Yeah iam ...
