True Street Turbo
I can accept paypal, money order, or credit card.
Thanks
Since I am changing things up it makes sence to list the "kit" whole:
-PTE 88MM turbo above
-6.0L Manifold turbo kit black coated with ceramic coated heat shields
-1.5-2.0'' "race"/short exhaust
-2.5'' y pipe painted with VHT high temp spray (can coat fairly cheap)
-Tial 44mm wastegate
-Tial 50mm bov
-Tube and Fin Phamspeed turbo kit Intercooler (has been installed to work on t-a/formula/camaro)
-strong 4-5 ply connectors and t bolt clamps
-aluminum intercooler piping polished
-will include stock maf(stock wiring will reach)
-made to work with 105mm tb and GMPP/elbow but can be changed for other set-ups easily
-includes iat sensor ( stock wiring will reach)
-includes Stainless works alternator brack(which works fine)
-flex a lite fans ?240?
- all the parts for the kit other then the turbo are used, they are not perfect, but not beat up or bad by any means
What kind of car it takes to work with the kit:
-depending on variables a stock cube up to 370 motor would be idea, a bigger ci motor can be used depending on details and goals
- YOU CANNOT RETAIN A STOCK A/C COMPRESSOR
-YOU CANNOT RETAIN STOCK FANS, ALTERNATE FANS ARE SUPPLIED
-The exhaust is short, slash cut, and it aims right at the ground. If you are worried about the car being quiet its not going to happen
How the kit has proformed:
-Here is a link to a thread that is all about the car........
https://ls1tech.com/forums/forced-induction/591898-408-stock-heads-88mm-turbo-24-psi-920-rwhp.html
The car was run about 15 passes and has been 5.73 at 125 mph in the 1/8 with a 1.39 60'. It hasnt has any full 1/4 passes. With a smaller motor I believe the car could have made a few more hp, but it is t4 and about as big as you can go in that platform.
There are pictures of the set-up here......
http://www.exoticperformanceplus.com/hotCars.php?car=70
This kit can be bolted on very easily and ready to race(depending on the supporting parts), I am asking $4500 shipped or best offer.
I know at this point the motor is big for the class and not ideal, but trying to find a turbo that will work.
Pte reccomended a 47-88 with a h cover, but I am worried about the exhaust side being restrictive.
I have Jose working on something also.
Any ideas?
