Rear turbo oil return pump recomendations
Old Mar 7, 2007 | 09:47 PM
lt170chevelle's Avatar
Default Rear turbo oil return pump recomendations
[SIZE=5]Ok heres the jist of it. I am piecing together a rear mount turbo kit on my chevelle and need to know what to do about a oil return pump.I made the mistake of trying to use a fuel pump and oil cooler with bad results. Jus wanting to know what you guys with rear turbos are running or what the manufacturers are using . Thanks Mako
Old Mar 7, 2007 | 09:56 PM
Eatinstang4life's Avatar
A lot of guys use this pump as well as my self. I have not mounted mine yet though but about to I will tell you how it works.
http://www.racerpartswholesale.com/mocal1.htm
ZL1Killa's Avatar
i'm using what sts said do. ran it to top of oil cap...but going to put it elsewhere next and install a breather. prolly adapt it to feed back on the dipstick
Old Mar 7, 2007 | 09:57 PM
trtturbo's Avatar
sent you a p.m.
Old Mar 9, 2007 | 10:42 PM
crzhrs's Avatar
That's the one I bought as well. Someone recommend using -10 line for the return. Do you guys think a line that big is nessary? The outlets on the Mocal pump are smaller than -10 line. I do not want to run that big *** line on my car! What size comes on the sts kits?
Brian
Old Mar 9, 2007 | 10:50 PM
Ping King's Avatar
i have a tilton for sale that is exactly like the mocal. It has 3/8 fittings on it that can be adapted to -8 AN.
I ran -8 on my turbo setup and returned it to the motor.
Old Mar 10, 2007 | 10:38 AM
i made up a stand alone oiling system in rear with a trans cooler ,fuel pump and a resevoir. so far so good . but curius about how much ya want for the tilton?
Old Mar 10, 2007 | 12:48 PM
Ping King's Avatar
id do 150 shipped..it has maybe 30 miles on it. If interested ill pull the head off and take pictures of the diaphragm if youd like.
