Spot for Oil return into Oil pan
Old Mar 8, 2007 | 02:37 PM
LS1AC-Cobra's Avatar
Default Spot for Oil return into Oil pan
where is a good spot on the oil pan to weld the bung for oil return line?
anyone pictures?
Old Mar 8, 2007 | 02:42 PM
trtturbo's Avatar
front of the pan in the vertical part.
Old Mar 8, 2007 | 03:21 PM
I've thought one of the two spots (either the upper or the lower) on the timing cover would also be a good idea (just have to use a 90° elbow so it won't interfere with the Belt)
click the picture:
Old Mar 9, 2007 | 07:24 AM
Ping King's Avatar
mine is setup like that, but on the opposite side.
Old Mar 9, 2007 | 09:33 AM
Country Boy's Avatar
Senior Member
heres where mine was.
Old Mar 9, 2007 | 03:27 PM
Carl, thanks for the pic!
I've thought that I tap into the the timing cover so that would spare me the hassle to remove the oil pan, 'cause I heard that it's kinda tricky to align the oil pan properly during installation, but since I want to replace the oil pump with a high volume pump I have to remove the pan anyways....
Old Mar 10, 2007 | 10:43 AM
Navy David SS's Avatar
Here's my twin's drain into front cover
David
Old Mar 11, 2007 | 12:44 PM
dave: that looks very nice but you're not running any accessories so you don't have to worry about any belt, I'm goin' to put a cog belt behind the accessory belt to drive the Supercharger so it's gonna be even more tight then it usually is...
Old Mar 11, 2007 | 07:59 PM
ALL UC2's Avatar
on my setup, i have a lq4 and the truck it came in had an oil cooler with feed and return lines on it. im trying to use them, never seen it done before, but i think it will work. anyone else have any input on this???
Old Mar 12, 2007 | 10:53 PM
Dragframe's Avatar
the drain aint supposed to have any pressure on it....
Old Mar 13, 2007 | 09:51 PM
FastKat's Avatar
Just curious, what pulley is that? It looks smaller than a stock pulley and probably gives you a little more room.
-Dave
David
Old Apr 5, 2007 | 03:37 PM
here are the pics how I finally did it, I decided to weld on that bung since the timing cover is not very thick and you can easily strip the threads in that thin aluminum:
Old Apr 5, 2007 | 06:05 PM
kickassT/A's Avatar
that looks pretty pimp... any concerns as to if the banjo bolt alows enough flow?
Old Apr 5, 2007 | 06:24 PM
smokinHawk's Avatar
looks good
Old Apr 5, 2007 | 11:49 PM
FastKat's Avatar
Default Front of oil pan
I put mine right on the front of my ugly CTS-C oil pan. Wow it needs polished. We welded some aluminum discs on so our pipe threads would have a little more meat to thread into. I think it's a 3/4" NPT with a 1/2" inside diameter. I wanted to go into the front cover but the crank pulley would not allow me to get a good drain angle.
